wastegate PROBLEMSS
so im about 90 percent done my turbo build, just not sure where i should connect the two nipples on my wastegate, theres one thats off the top and one on the bottom, thanks for the help guys!
Someone please correct me if I'm wrong.
Why don't you want to use a boost solenoid?
Connect the bottom port to your compressor housing and leave the top port open if you're not using an electronic boost controller. If you're using a manual boost controller, route it inline with the bottom port.
