Sponsored by: CARiD
Air Filter & Intake
Old Apr 25, 2017 | 01:04 AM
willyummies_'s Avatar
Default Air Filter & Intake
What's the difference of changing just the air filter (K&N), and changing/getting a K&N intake. power difference, and performance wise
Old Apr 25, 2017 | 07:42 AM
Car Analogy's Avatar
This is a sound/appearance mod, not a power mod. The power difference, if any, isn't worth the cost of the system. The S filter is not a restriction for this motor. So a better flowing filter isn't buying you anything. Especially if that filter can let more damaging silicates into your motor. Use the stock filter. Personally I would recommend the stock filter, even if you do go with a K&N (or any other) intake. Mate stock filter to whatever intake you think looks/sounds the best.
There are mods you can do to your stock airbox for more sound, if that is all you want.
Old Aug 10, 2022 | 06:05 PM
Country_S2k's Avatar
if your main concern is "sound". have you done the stock air box mod ? either way i would suggest using any filter you'd like but keep the existing plumbing factory for hot/heated air concerns.
Old Aug 10, 2022 | 08:39 PM
cosmomiller's Avatar
Top Answer: 1
I don't recall which ones have had issues but I seem to recall others inadvertently getting water ingested by the engine as the design of the air filter allowed water to be sucked in. Not good.
Old Aug 11, 2022 | 05:53 AM
You're thinking of the intakes that place filter down low, behind bottom of bumper. If you drive through any standing water, and filter becomes submerged, engine will suck water and hydrolock. Blow holes in pistons, block, etc.
Filters at stock height much less susceptible (you'd have to drive through water as deep as hood).
Old Aug 11, 2022 | 06:50 AM
rush2redline's Avatar
I have the K&N intake and the OEM Intake with K&N Filter and the Air Resonator blocked off. I'm going back to OEM with the K&N filter.
Supposedly K&N has better mid-range and loses some peak power in the top end. For the K&N to be efficient, it needs to be effectively blocked off from the engine bay to reduce heat soak. We use things like tape and foam noodles to block it off but honestly, it looks silly. Pick an intake you like the look and sound of.
You'll gain more cost effective power by changing your exhaust headers and high flow cat.
Danwolski
Mar 30, 2012 11:06 AM
vtecowner
Jan 5, 2012 05:22 PM
Jwslick
Jul 14, 2008 09:00 PM
Pstar
Jun 19, 2004 05:02 AM
lostsol
Oct 27, 2002 11:13 AM
