Sponsored by: CARiD
DME Engine Torque Damper
Old Mar 10, 2009 | 02:33 AM
deibit's Avatar
Default DME Engine Torque Damper
Hi!
I recently got a DME ETD
It looks like this:
Ok, looks cool, but the main problem is that it comes without installation instructions.. (i know it should be quite straightforward.. but...)
basically the installation of the heatshield is no problem, the big piece over the strut is also no problem (but does anyone knows the torque value of the nuts?).
The problem is that I am not sure where to fix the ETD to the engine.. the mount is the small black piece (over the ETD in the picture) but where should I fix it? which torque? I am a bit concerned because of fixing things to the alu motor block so I want to be sure that I am doing it right.
Additionally.. the ETD comes with a set of rubber and a set of urethane bushings.. how do I know which is which? inside of the ETD there are two red bushings and the ETD comes with two black bushings (second bag in the picture starting from the top)....
Tnx!
Old Mar 10, 2009 | 02:41 AM
#Amuse#'s Avatar
You got a PM.
Saludos
Old Mar 10, 2009 | 04:32 AM
energetic's Avatar
Check these links. Hope they can help you out as well.
https://www.s2ki.com/forums/index.php?showtopic=146182
https://www.s2ki.com/forums/index.php?showtopic=235689
https://www.s2ki.com/forums/index.php?showtopic=180246
https://www.s2ki.com/forums/index.php?act=m...mage&img=316124
https://www.s2ki.com/forums/index.php?act=m...mage&img=100097
Old Mar 10, 2009 | 05:28 AM
deibit's Avatar
Thanks
It seems all those ETD are quite standard with really small variations
Ok, the ETD mount is fixed on the engine side inside the engine lifting bolt next to the VTEC solenoid. I also found out that the red bushing is the stiffest one and the black one is the softest one (seemed obvious.. but who knows...)
But I am still not sure about the torque values of the stud bolts (49Nm?) and the torque values of the allen bolt attached to the engine block... anyone?
Old Mar 10, 2009 | 10:59 AM
JackS's Avatar
I don't know the answer but I would think torque value would be approx. the same for any bolt entering the aluminum block. Consider using the same torque as a head bolt.
s2k_jay
Jan 31, 2018 01:17 PM
Jojo-yoyo
Sep 16, 2017 05:17 AM
s2konroids
Mar 23, 2010 09:52 PM
prodriverex
Jul 5, 2008 08:30 PM
kenstyle
Sep 19, 2006 05:30 PM
