Sponsored by: CARiD
ECU RE MAP
Old Aug 5, 2012 | 08:02 PM
Richie.js's Avatar
Default ECU RE MAP
HI,
I Just fitted a 63 series K&N FIPK air charger and a 60mm Invidia test pipe to my 2005 S2000. I was wondering if anyone has done anything similar and if you needed to get the ecu re mapped? Also if you have had any issues down the line.
Thanks in advance
Rich
Old Aug 5, 2012 | 08:17 PM
s2000maniac's Avatar
you can't "re-map' an s2000 ECU...
Old Aug 5, 2012 | 09:17 PM
meccjoo's Avatar
he probably means "tune" and yes you can remap s2000 ecus, 06 and newer.
Old Aug 5, 2012 | 11:05 PM
I know that... The OP has an 05 which you can't tune or remap. Unless you get a aftermarket ecu
Old Aug 6, 2012 | 12:47 AM
liquid_helix136's Avatar
with a test pipe you can lower vtec to ~4k and gain a good bit of midrange from 4k-6k. However in order to do so in an 05, you will have to buy an aftermarket ECU and get it tuned, which will cost about ~$1500. So the question is, is 25 ft/lb of torque from 4-6k worth $1500 for you?
Old Aug 6, 2012 | 10:06 AM
Richie.js's Avatar
Thanks guys, from what you're saying the short answer is no unless I want to gain more torque which isn't something I want to get into at the moment
Cheers,
Rich
Old Aug 6, 2012 | 10:21 AM
Biohazard's Avatar
you will still gain some power the way the car sets. You do need to do a ecu relearn however. Take the negative cable off the battery, wait 10-15 seconds, then reconnect. Start the car and do not touch anything, just let it sit there and idle for 10-15 minutes, turn it off and then go start it again and go have fun.
Old Aug 6, 2012 | 11:26 AM
Richie.js's Avatar
I'll try that thanks very much
speakeasy2009
Aug 10, 2012 12:13 PM
Popa
Jun 29, 2010 03:11 AM
IsaacNewton
Nov 16, 2006 10:35 AM
J33LUS
13
May 31, 2006 03:37 AM
duck69
Apr 21, 2004 11:05 PM
