Sponsored by: CARiD
S2000 Window Trim Replacement
Old Oct 16, 2025 | 10:18 AM
lyndon88's Avatar
Default S2000 Window Trim Replacement
I've just finished washing the car and noticed after 20 years, the weather has perished the rubber weather trim on the drivers side (UK). It's splitting away.
I've only just seen this and had a quick glance on eBay, genuine ones look as through the circle about £90ish. If I'm even looking at the right thing.
Before I buy the parts and attempt to replace it. Has anyone done this before? Is it a case of a simple swap, or has the door card got to come off and other bits?
Old Oct 16, 2025 | 02:19 PM
noodels's Avatar
Easy replacement do it now to avoid price ^ its not going lower on future
Old Oct 17, 2025 | 05:50 AM
dwb993's Avatar
Easy fix.
Some tips:
1) The material of the replacements was a bit different than my original AP1 pieces.
2) When removing the old pieces, be careful of the plastic clips breaking off. They will fall to the inside bottom of the door and can potentially block off drainage.
3) There is a DIY here somewhere for replacing these pieces.
Edit: Found it! https://www.s2ki.com/forums/s2000-mo...lding-1085317/
Old Oct 17, 2025 | 07:35 AM
lyndon88's Avatar
Originally Posted by dwb993
Easy fix.
Some tips:
Superb, thank you for that. I'll have a good read through it all before I make a start.
Rickos
Sep 3, 2022 09:42 AM
JB Morrison
May 21, 2022 06:50 AM
ValveBounce
May 25, 2017 05:41 AM
Alps Pacino
Apr 4, 2017 10:18 AM
kew2k
May 28, 2013 02:03 PM
