Shift Knob Problems
Hey guys,
So I'm in the process of changing my shift knob from a metal one to one that is either leather or resin based. However, as I was trying to get the knob off I noticed there is no locking nut on there. I go to twist it, and it turns, but it feels like the whole shifter is turning. It will only turn about half a turn then get stuck. I'm not sure how to remove it. Any ideas?? Thanks.
Vince
Vince
So the knob that is currently stuck on your shifter doesn't have a lock nut on it? Just grab that ish with both hands and twist counterclockwise. Hopefully the person that put it in there didn't use loctite or something similar.
I'd remove the shifter, it'll be a pain with the knob still on but they'll be less risk damaging something (shifter, interior surfaces, fingers). Once you get it off you'll probably have to rethread the shifter, easier done off the car. Regrease the shifter when reinstalling while you're at it.
If it is the stock boot, then take the center console off as much as you can. The top of the boot is actually formed with a little zip-tie at the top, at least mine is. Cut the zip-tie and see if it opens up enough to get it off with the knob still on.
