Sponsored by: CARiD
Windscreen Install
Old Nov 23, 2014 | 11:57 AM
JulioOchoa23's Avatar
Default Windscreen Install
hey guys, I just got the windscreen for my ap1 but i dont know how to install it. it looks rather easy, but I know I'll find a way to screw it up so I'd rather get some help. I looked up a how to online and got a bunch of ones that werent oem.
Old Nov 23, 2014 | 03:44 PM
A. Dos Santos's Avatar
I did mine a few months ago, it is really easy. first, underneath of the secret box thing (the part where the wind screen goes onto), there are two spots where the plastic is molded and you can use these as a guide. these will be your drill holes. I made two small holes inside of the molded holes, then test fitted. If you can get it perfectly drilled out, then your holes will line up perfectly. Assuming you have the bolts, the rest is easy. just bolt it in, and snap the plastic caps on. I'm a retard and forgot to order the nuts, so instead I threaded the plastic with a tap set, and I just bolted it to the plastic. 13000km's later, 200km/h+ and no issues.
tldr
1 drill two holes from the underside of secret box door thing, where there are already spots for drilling
2 put windscreen on
3 feed bolts through
4 thread nuts on and tighten everything down
5 put plastic caps over bolt heads
you're done.
super easy
Old Dec 7, 2014 | 06:38 PM
tldr
2 put windscreen on
you're done.
super easy
Thank you so much DDD
caremail0
Nov 21, 2013 01:59 PM
caremail0
Oct 30, 2013 09:21 AM
smokenrowboy
Oct 26, 2010 02:53 PM
cyman83
Dec 22, 2005 09:16 PM
RUGBY
Aug 21, 2001 07:00 AM
