Advice on Necessities for DE Setup..
Originally Posted by nissanfanatic,Oct 27 2010, 03:37 PM
The things I know I would need to have fun on a track:
Cobalt Friction XR2/XR5 pads for a fade free track day, though I can drive around the fade on the updated OEM pads
Good brake fluid
Max front camber/2.0 negative rear
good tires
good oil
MT90
Data acquisition
Since you mentioned RPF1s and coilovers, might I recommend 17x9s all around, 255s, and CR front springs/shocks. I run this setup and I really like it. Plus, it can be had on the cheap.
Good brake fluid
good tires
good oil
MT90
Data acquisition
Originally Posted by NewScooby,Oct 27 2010, 02:58 PM
AP1 vs AP2
Amount of front toe out
Amount of rear toe in
Tire pressures
To many variables for me to guess. I have run with the bar full stiff at an autocross with 17x9 949's and 255's all around and it understeered and generally the handling sucked.
On track with the streched 225 and the saner bar on either full soft or in the middle the car works for me. It trail brakes very well, rotates good underthrottle, and can oversteer at will.
Tire pressures
but if you have the same size wheels I don't think theres an advantage to not running the same tire all round or a larger stagger like 235/255 and I'd start at soft with the bar and work up
as previously mentioned, your mod list should be:
- Brake pads (whether it's hawk, cobalt, carbotech, etc)...
- solid alignment (whether it's stock or Euro spec)..
that's it. then work towards adding the rest as you progress.
I am going with front sway only as suggested 1st time out also..
Mike
Originally Posted by Mike@AWDmotorsports,Oct 27 2010, 07:16 PM
You think I should be setup 17x9 all around?? I havent installed the wheels yet.. 255 all around as well?? Thanks for the info..
Originally Posted by FormulaRedline,Oct 28 2010, 09:14 AM
The car has a 50/50 weight distribution and not a ton of engine to overpower the rears, so it can make pretty good use of a square tire setup. Just keep in mind our earlier discussion, you may need to stiffen the front/loosen the rear to take advantage of more front tire.
Mike,
I saw no mention of your car being AP1 vs AP2. Understand that they are diff. cars that are set up diff. from the factory regarding sways, dampers, springs etc. Be sure to pay attention to this when reading the forum. I too am in S.Florida but usually drive with HOD. Would be nice to see more S2000's on the track down here.
Originally Posted by miamirice,Oct 28 2010, 11:44 AM
Mike,
Mike
Regarding set up:
I have stock: DOT 4 fluid, Carbotech XP10 front/XP8 rear.
I found I was well beyond the wear triangles on the front tires so I got a more aggressive alignment: -1.8 front, -2.5 rear. You will need the SPC camber adjusters if you want to add a lot of neg. camber.
The car really does fantastic stock but I added R compound tires and now want coilovers as the R compounds really out perform the stock suspension.
One more thing to know if you have not learned the hardway, when your gas gauge says about a quarter tank, you need to put fuel in.
