Autocross setup help
I'm running this year in a local street tire class that would allow me to use the lower perch on my shocks. On a car otherwise set up in AS trim (Comptech FSB, Revalved Konis), is there any advantage to doing so?
The only reason I ask is that it's time for an alignment, and If there is I'd rather do it now before I get it aligned if I'm going to make the change. I'm not really concerned with looks, etc ... or worried about the other problems of having a car that is lower than stock, since it's pretty much an autocross and weekend fun car. But I'll take any advantage that's legal (and free)!
If it makes any difference, I'm running 225 / 225 direzza star specs. Haven't run them on course yet, but I picked them up cause I got a good deal on them, and from the street driving I've done, I think they'll be worlds better than the Hankooks I was running before.
Thanks in advance for any information.
I do not plan on running AS this year. I'll probably run one divisional, but since I'm on street tires, and won't be competitive anyway, I can run BSP if I lower the car.
I understand what modifications I can and can't perform for different classes, I'm trying to figure out if there is any performance benefit to lowering the car with my current setup.
I was planning to go back to race tires this year, but I've already missed half our season, half our divisionals, and nat tour, so I'm going to save some $$ and wait till next year.
Yeah looks like I might have to. Unfortunately, I don't have any data logging. Not sure if my butt dyno is good enough to provide accurate information.
Does anyone see any reason other than the classing issue that I shouldn't test it?
Generally speaking, lowering your car will allow you to get more camber, if you need/want more camber. Depending on how much you lower it, you run the risk of hitting the bumpstops in turns, which would have a material adverse effect on handling.
As Mike says, the only way to really tell with your car, your driving and your courses is to try it out.
Apeatwo
Feb 20, 2014 07:27 AM
AndrewMcG
Apr 1, 2013 08:04 PM
