Bilstein
Old Jun 17, 2010 | 08:24 PM
  #141
Vitt's Avatar
Originally Posted by INTJ,Jun 17 2010, 08:19 PM
I was looking at Macr88's work and wondered if we could get an advantage to just swapping out springs street and track, using the cobb to give more ramp. The roads are rough here and I want a little bleed but good control. I haven't bought the shocks. Almost got a cheap set of Ohlins, but they have the single control for both reb and comp.
Got it, thank you.
Old Jun 21, 2010 | 11:16 AM
  #142
2159ClassicRed's Avatar
Originally Posted by chetly,Jun 15 2010, 11:31 AM
Usually they get anywhere from $100-$150 per corner for a revalve.
Contact Guy... He's good.
http://ankenyracingenterprises.com/contactus.htm
Got a quote from Guy of $125 per shock for a revalve on a set of Miata dampers.
Old Jun 24, 2010 | 04:49 PM
  #143
INTJ's Avatar
That is not bad. I would get a dyno from him.
Old Jul 9, 2010 | 05:04 PM
  #144
macr88's Avatar
I think the PSS's come with the COB digressive valving that you're talking about.
Old Jul 10, 2010 | 11:03 AM
  #145
INTJ's Avatar
Do you have a pic from yours?
Old Jul 10, 2010 | 11:44 AM
  #146
macr88's Avatar
No, but I do know mine were digressive with a check valve. The older digressive pistons didn't have a check valve.
I can take a pic the when I see them again but it might not be for sometime.
Old Jul 11, 2010 | 02:09 PM
  #147
macr88's Avatar
I have the one on the left and the one that was in my shock was the one on the far right.
Old Jul 12, 2010 | 12:22 PM
  #148
Orthonormal's Avatar
I suggest contacting Bret Norgaard at Bilstein in the Poway, California office. Back in 2003, the revalve service was $55 for their HD shocks, $100 for PSS9 adjustable shocks, and somewhere in between for non-adjustable PSS shocks. The current rate for HD shocks is $65.
Old Jul 12, 2010 | 12:29 PM
  #149
macr88's Avatar
Thanks John
Can never have enough contacts
Old Jul 12, 2010 | 12:43 PM
  #150
macr88's Avatar
I just wanted to post up a bit more info I found out about the SOS top hats.
The gain that would be had by flipping the top hat over, this was recommended by Chris at SOS.
Not a good idea and it's good that it won't even fit due to the large diameter of the pillow ball
carrier. Never flip a top hat, the designed carrying loads are completely different and I was
amazed he even mentioned that. This was his only resolution to this problem I was having.
This wear inside the top hat was due to the pillow ball being loose in the top hat causing
knocking that sounded like either a bad pillow ball or loose shock nut.
This is the wear from 3 days of use and was most likely caused by using the shorter screws
that hold the pillow ball in place inside the top hat.
This one was fine.
I guess they ran out of the longer screws that hold in the pillow ball. The one that was making noise
had the shorter screws.
The factory bump stop was what was used with stock top hats and Bilsteins. The tires use to just
barely touch the fender liner over large bumps.
The black bump stop is what I had to use with the SOS top hats and I'm nowhere near touching
the fender liner at full bump.
