Canton pan thoughts here
Thanks anorexicpoodle for a clear and concise comparison using real data between the two setups.
A few added considerations:
Moroso Weld In Baffle:
Pro: significantly less expensive
Con: leaves one side open by the pickup without a trap door (I believe)
Notes: make sure you use a welder who has experience with Aluminum, welding dissimilar metals, and just does a really good job.
Canton pan:
Pro: trap doors cover all directions
extra bungs for oil temp and oil return
Con: definitely more expensive
Canton pan:
Bought my Canton oil pan as part of the original group purchase.
Noticed a leak last year, but only got to look at it last week on the lift at Billman's. Initially baffled as to where it was leaking from. Finally found a defect in the weld line.
Attachment 141171
Attachment 141171
I bought mine as part of the original group buy as well. Last year I pulled it off due to a slow leak. Also looks like I had a bad weld, but my pan looked like it made some contact with the front rubber stop enough to cause an indentation. I don't really blame the pan. I cleaned it and had a friend weld it up. Seems good as new now.
my baffle back weld broke off and i rewelded it
the seam weld started leaking requiring another weld repair and re installation.
lastly the back weld repair which has been repaired for 3 years has begun to leak.....
time to fix the fix. still a great pan
zerosleep
May 18, 2011 07:46 AM
stack
Aug 21, 2009 05:26 PM
