DC Prosolo
Old Apr 9, 2012 | 08:32 AM
  #111
sirbunz's Avatar
Originally Posted by nlink720
B) [media]http://www.youtube.com/watch?v=vt2eFpTM1oI&feature=relmfu[/media]
Don't laugh too hard...
HaHaHaHaHaHa
... "No..."
No worries, I have been there many times. Two weeks ago, I stopped the events because I crushed the timing light!
-Marc
Old Apr 9, 2012 | 08:33 AM
  #112
nlink720's Avatar
Also, I drove to the event with the silencer in, which I normally do not do that was the first time. Perhaps the short term fuel trim was altered on the 3 hour drive up? Maybe just resend the current FP tune and leave the silencer out? I drove home with it out, like I normally leave it...
Old Apr 9, 2012 | 08:36 AM
  #113
nlink720's Avatar
Yeah Marc... I laughed last night with tears coming out. Hadn't seen that in a few years. Things are so much better now. I told Imran and some of the 1st time Prosoloers to just relax like Jadrice says, and to look at my video, which is shamefully hilarious
Ohh Nooo!!
And the finish worker taking out my cones was funny, and my knucklehead friend Andy commenting was funny.
Fail
Old Apr 9, 2012 | 08:48 AM
  #114
an2ny's Avatar
Steve and Jadrice,
I switched to Mobil1 just before Dixie. I was using the OEM Honda stuff before with no problem.
I heard people say the S burns Monil1 for some strange reason. It is either that (what I really suspect), or I did notice that the oil dipstick was raised upwards by about 1/2". It was almost loose to the point that oil would come out, but not quite. I don't think that would be it, but what if air was getting in???
I was planning on doing a complete oil change and just leaving the filter since the car has less than 1,000 miles since the last oil change. Ideas?? I appreciate the attention to [my car's] big beautiful ass.
I have been using Mobil 1 for years and never had an issue with oil burning.
About the oil dip-stick try putting it in the other way around, you may have it backwards. Yes, you will lose compression and about 100hp…
Old Apr 9, 2012 | 08:57 AM
  #115
Aristoi's Avatar
I do not like mobil 1 in the S2000 at all! That is what i switched to when i first bought the car and had a timing chain tensionaer failure before the next oil change. I think the problem is Mobil 1 is at the low end of the spec for 10w/30 viscosity. Last time i compared data sheets for off the shelf synthetic oils, all were thicker than mobil 1 with the exception of Pennzoil only being a little higher. I used Valvoline, Royal Purple, and currently running Castrol and never had the issue come back. Do a search for Mobil1 and TCT and see it is an issue often seen in that combination of variables. As for the raised dipstick i think that is pretty normal when autocrossing.
Old Apr 9, 2012 | 09:10 AM
  #116
steguis's Avatar
Your car is so fast it pops the dipstick up in VTEC
Old Apr 9, 2012 | 09:22 AM
  #117
Rodney's Avatar
that is a pcv issue. excessive crankcase pressure will pop the dipstick.
i too have had excessive burning with mobil 1 oil. so much that i thought i had to put a motor in the car. changed to agip synthetic, and the oil burning problem ceased to exist.
Old Apr 9, 2012 | 09:28 AM
  #118
nlink720's Avatar
Yeah, I agree. I had dismissed a lot of the negative information on the Mobil 1 since there always seemed to be someone supporting it (Anthony?). I will definitely switch back. I take oil samples and send them to Blackstone. The OEM oil was doing just fine at 5,000 mile intervals.
I do wonder if the silencer affected the fuel trims, but even after 8 runs the issue was still there... I would think that would have been enough driving for the ECU to have adapted to the lack of silencer in.
I will change oil and then record the exhaust prior to the event, and go from there. Oil level was at 100%, not overfull.
Thanks for the assistance everyone.
Old Apr 9, 2012 | 10:19 AM
  #119
steguis's Avatar
As for the dipstick popping by the way, just put it in backwards and it stays in there tight.
Old Apr 9, 2012 | 10:21 AM
  #120
Rodney's Avatar
or you could fix the pcv issue, the proper way. stick to solving windows issues geek.
