Fuel starvation?
Old May 6, 2013 | 12:03 PM
  #41
ScienceofSpeed's Avatar
Former Sponsor
We experienced the same problem and have developed a fuel surge tank with internal pump which buffers supply between the factory fuel tank and the engine. It is compatible with the factory fuel tank & fuel lines. It has not something we have considered for production but if there is interest, we will consider it.
Old May 6, 2013 | 12:09 PM
  #42
Road racer's Avatar
Where do you mount your surge tank? Any pics? I would like to retain my spare tire for road trips.
Old May 6, 2013 | 04:05 PM
  #43
CKit's Avatar
The full blown one mounts anywhere you want it to. I have mine in the corner of the trunk.
Old May 6, 2013 | 09:16 PM
  #44
rrthorne8's Avatar
full blown is surge tank is the way to go if your rules allow!
i fuel starved at 8/10's of a tank before installing a secondary fuel pump in the right side of the tank with one way valves on each before they combined and left the tank.
now i can run most of the tank before running out.
get full blown if your looking for an easy solution with support
Old May 21, 2014 | 09:31 AM
  #45
Former Sponsor
End fuel starvation:
http://scienceofspeed.com/products/e...el_surge_tank/
Old Jan 9, 2019 | 10:28 PM
  #46
altimatic's Avatar
Originally Posted by sto405
I had this problem and it was a faulty fuel presure regulator. Check your vacuum line that goes from the regulator to the intake manifold. Take off the vacuum line and sniff it if it smells like gas your fuel presure regulator should be replaced. It solved bogging, and the whole fuel starvation problem for me.
Very sorry to bump up this old thread, im also having this issue, that thin hose (with the yellow line in the picture) smells like fuel. is this the hose you mentioned which indicates a faulty fuel pressure regulator?
did you change it with oem? or should i go aftermarket on this piece and call it a day
My car gets the left turn fuel starving and hesitation occasionally.
I hope youre still active on forums!
Old Jan 10, 2019 | 12:02 PM
  #47
ConeKiller2's Avatar
Fuel pressure regulator is not a problem. The tank design causes starvation. Very rare for a bad regulator
staylor725
Jun 25, 2017 04:17 AM
mullens
Dec 25, 2011 01:19 PM
kenny_son
Apr 19, 2009 01:54 PM
gerryk
Jan 6, 2008 08:37 PM
Reaper 6A
Jul 15, 2007 07:04 PM
