Prepping for BSP
Old Dec 18, 2012 | 07:23 PM
  #341
steguis's Avatar
Well my letter to the SEB regarding allowing the use of non OEM hardtops (letter #9604) has been reviewed and a response is coming in the next fast track. I don't think this is going anymore. More than likely it's going to say, thanks for the input but we don't believe it's in the spirit of the rules or something like that but at least I tried LOL.
Old Dec 18, 2012 | 08:05 PM
  #342
03threefiftyz's Avatar
If they do, I want to be able to buy replica Nismo body parts...instead of the 3.65 million dollars it costs for the OEM stuff.
Old Dec 18, 2012 | 08:48 PM
  #343
steguis's Avatar
Why can't you? According to the rules for instance I can run a replica CR wing using any material.
Old Dec 18, 2012 | 09:09 PM
  #344
Bullwings's Avatar
Originally Posted by steguis
Is the SPC camber joint legal in BSP? My J's racing offset ball joint is on its way out and both the J's Racing and the Hardrace ones are backordered.
FYI, it looks like Evasive has all three in stock - hardrace, and J's with and without the roll center plate. Granted, I didn't try placing them in my cart since I don't need them. GL
http://www.evasivemotorsports.com/mm...ARDRACE-CAMBER
http://www.evasivemotorsports.com/mm...Code=JS-CAMBER
Old Dec 18, 2012 | 09:17 PM
  #345
steguis's Avatar
Already contacted evasive and it's backordered. I did locate another vendor that had it in stock but won't disclose where until mine actually ships. At this point if you don't get it from someone who actually has it in stock you're looking at a 2 month wait for either J's or Hardrace.
Old Dec 19, 2012 | 07:02 AM
  #346
sirbunz's Avatar
I'm still running the SPC joint from my STR car (swapped upper control arms with joints) with no issues for 1.5 years. They are still really firm. Is there any reason you want the J's joint instead? More clearance?
Also, my replica hardtop is due to be shipped today. Send me your references/supporting remarks and I will submit my own letter. It would be great to be able to run this in the rain. It also saved me 2000 compared to an OEM top.
-Marc
Old Dec 19, 2012 | 07:12 AM
  #347
steguis's Avatar
Just reference my letter number I listed in my post above. I prefer to push the bottom of the wheel out than pull the top in for clearance especially for the kind of tires/wheels we're going to run.
Old Dec 19, 2012 | 07:17 AM
  #348
ConeKiller2's Avatar
Well the 18x11 should be here Friday and the bfg 275/35/18 will be here next week. I will post a picture comparison between the 17x8.5 with 255 hankook. 17x10 with 275/40/17 bfg and the 275/35/18 on 18x11 when I get everything mounted up. First event of 2013 will be Jan 6 on concrete. Well see how the car feels/works with new shoes
Sent from my Galaxy Nexus using Tapatalk 2
Old Dec 20, 2012 | 12:16 AM
  #349
daverx7's Avatar
Originally Posted by rocket71
Feels like this thread needs broken down like the STR thread before it gets much further.
I agree. If there is a section that have the same allowances between STR/SP, then rename the thread to include SP.
Old Dec 20, 2012 | 05:41 AM
  #350
steguis's Avatar
About the only thing we share with STR is the suspension choices (though setup might be different) and maybe diff options.
