Prepping for BSP
Not trying to tell you what to do, but keep in mind early acceleration is much more valuable than another mph or two top speed in 2nd. I dealt with this in AS/BS (AP1 vs AP2 gearing) and the datalog showed the most time was gained from early acceleration. (obviously other factors are involved) 60 mph will be enough for most National courses. We will be well above that mark.
-Marc
-Marc
http://www.tirerack.com/tires/tires....r&tireModel=A6
-Marc
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
fronts seem to fit fine, rolled and pulled. rears are going to need a lot more for sure, will get pictures going soon as i put the rear subframe back in.
As for ap2 engine to ap1 tranny, its pretty simple, had some shims made to take up the 10mm extra space in my driveshaft coupling, then used ap1 8mm bolts, will see if they hold up, but hey all ap1's last with 8mm so it should be fine
