S2000 STR prep resource
Old Aug 19, 2011 | 11:36 AM
  #4501
KrazyKarl's Avatar
Still some good HP numbers from both cars, I should probably get some baseline dyno numbers before I start making changes...
Old Aug 19, 2011 | 11:42 AM
  #4502
daverx7's Avatar
For what I want, I would be happy to give up upper end HP for some low end TQ. (Wow, got to whine a 2nd time in one day. Haaa!) I wish I could show you my dyno results post VTACK controller install/tune. I must admit that I did get some low end benefits from my high dollar header, but you know one can never have enough.
Old Aug 19, 2011 | 11:49 AM
  #4503
KrazyKarl's Avatar
Running in STR was part of my reasoning for picking an 06+ model so I could use flashpro, that and LBP was the color I really wanted. Once the last event is done in October it'll be time to start building the car right up until the roads are salted and it has to spend the winter in the garage. Damn winter, who knew it would always get so cold and snowy in Minnesota??
Old Aug 19, 2011 | 01:10 PM
  #4504
robinson's Avatar
Here are my results from various parts and tunes. Check out the mid range gains, no hondata flash.
https://www.s2ki.com/s2000/topic/869...#entry20644104
Old Aug 19, 2011 | 01:55 PM
  #4505
ConeKiller2's Avatar
Here is an 04 with knn intake, berk 3 inch header back with 3" magnaflow cat and Aem ems series 2
Sacha
Old Aug 20, 2011 | 09:56 PM
  #4506
Random1's Avatar
Finally corner balanced...
Total weight = 2675 lbs with no driver. Everything was removed from the car including carpets, empty glove box, trunk, etc. Top was down as well.
50/50 front/rear balance was achieved on each side with me in the car, but there is a 90 lb bias to the driver side. Achieving a left right balance does not appear to be possible with driver in car.
Is this what everyone else has experienced?
Most of my weight reduction has been in the exhaust which is on the right side. To get no left right bias it would appear that the ride height would need to be significantly different.
Realistically I could lose about 10-15 lbs to be at my ideal weight.
Old Aug 21, 2011 | 03:45 AM
  #4507
josh7owens's Avatar
you took out the carpet and all the trunk pieces? Is that even legal?
Old Aug 21, 2011 | 06:31 AM
  #4508
bronxbomber252's Avatar
I think he meant the floor mats...
Old Aug 21, 2011 | 04:47 PM
  #4509
chetly's Avatar
For those of you that have an 06+ AND flashpro, are you using the launch control feature? I'm curious how it works and want to see if it's worth setting up or not.
K, thanks, bye
Old Aug 21, 2011 | 04:55 PM
  #4510
alvanderp's Avatar
K, thanks, bye
I've only found it useful at Pros, I've never found it useful at a regular Solo event.
