S2000 STR prep resource
Originally Posted by daverx7,Jan 6 2010, 09:31 AM
^^good assumption as this car has a pretty aggressive alignment and has the most camber I can get out of the fronts, which is pretty close to what you mentioned. Thanks for sharing this!
This is good news that might work for 2010. I have a feeling that if the AP1 proves to be decently competitive, I will convert from race rubber and go totally in STR.
Another thought.... To slightly compensate for my inability to flash my ECU, I have also been contemplating going with a lighter wheel than the soon to be 949's but they are narrower up front causing a tiny pinch with 255's. However the offset might become a problem as from the way I am reading it, it pushes me out 5mm over what the 949's.
https://www.s2ki.com/forums/index.php?showt...post&p=17855539
Any opinions on this approach? Am I foolish considering this set of wheels over the 949's? Remember, I have never claimed to ever knowing what I talk about. LOL
Hmm... I wonder if the stocker guys would care if I had my fenders tweaked STR legal, but use my legit BS wheels and tires (245/45-16 /BBS six spokers)... which we all know would not benefit from the fender tweaking. Of course this would be worst case scenario and only done if for some reason my poor old car still rubs with the 255's.
-Dave
-Dave
When you decide to go STR wheels, just get the 949 wheels. There's only one set of wheels that are better, but require $$$ due to the JDM bling factor.
As far as the disadvantage of the AP1, I think you're overexaggerating it a bit. Yeah, we can't reflash like the 06+ cars can, but one of the benefits of that is that they need to raise their redline to get better gearing, whereas the AP1s obviously don't. VAFCs will get the job done. Main thing the AP1 needs is to lower the VTEC engagement. After I+H+E, a good tune will pick up some power. We'll still be at a disadvantage to the AP2 in regards to power, but I also like peace of mind that I'm not gonna grenade my motor either like we'll start seeing with some of these AP2s down the road.
Just my 2 cents.
James Yom
I have an 01... with I/HFC/E and im stalling suspension later this week, Plus I got some used Volks in 17x9 +63 14.8 lbs each... Im not gonna slam the car, just a real mild drop so Ill let you know how I do on the rubbing and performance front.
I was originally waiting for the 949 wheels, but when I found these wheel used at a good price I jumped on them. If I were to get a second set of wheels for Rain or something I would go 949.
On the AP1 front, I think it will be interesting to see how they do when prepped nicely, However I don't know if any National guys are gonna be prepping Ap1's so I don't know if we will have an answer to that question. Currently the BOD is looking at expanding the use of Piggybacks allowed in ST classes, if they do that would certainly close the gap, but VAFC will be a big help anyway especially in 00-01 cars since they run real rich anyway and could be leaned out a bit. VAFC's can do A/F ratios and Vtec point legally so we at least have that.
I gotta get Sal Dipompo to run my car at a bigger event and see how it does. that will give a better indication of my car's abilities than I ever could.
Dave, we should do a dyno day (same dyno, same day) before and after the cars are tuned. Maybe some others can join? I'm sure this will help give some data out to the community. We can both use the same wheel/tire setup if it matters.
As for tearing up an AP2 motor, I just don't see any evidence to date indicating the <8600 redline will harm the motor outside the normal wear and tear expected from the increase in revs. For every horror story I have found, there are a plethora of success stories, so nothing unusual IMO. Still, I wouldn't go over 8500 if I were to flash my motor today just as Hondata recommends. I'm also keeping a close eye on the engine management thread in regards to the Flash Pro and any updates to this topic. If anyone has new info, please post!
+1 more for the low-prepared STR local and B-Stock National intentions for next year. I plan to use (4) 17x8.5 OEMs on whatever tire is popular when I buy. Everything else will be stock for now.
-Marc
-Marc
...AP1 Stock class mods
...AP2 Stock class mods
...AP2 Stock class mods but with it flashed
Crap, there goes my chance to win STR or even get 2nd place trophy at home events (if David Patrick decides to go with a STS prepped Miata in STR). Oh well, at least it will be cheap fun! LOL
-Dave
Originally Posted by sirbunz,Jan 6 2010, 01:29 PM
Dave, we should do side by side dynos (same dyno, same day) before and after the cars are tuned. Maybe some others can join? I'm sure this will help give some data out to the community. We can both use the same wheel/tire setup if it matters.
I mean, Honda's engineers didn't drop the RPMs an even 1000 for the AP2 becuase it's a nice round number, there are lots of factors that went into it. If they could have just given it 200-300 more RPMs, you wouldn't drop out of VTEC every time you shift, and you'd spend more time in the meat of the power band. But the fact is, they didn't. I do hope that all of you guys bumping up the rev limiter have no issues, but if I were to buy someone's AP2, I'd shy away from any that were used in STR...
Originally Posted by daverx7,Jan 6 2010, 01:07 PM
I have two sets of AP2v1 wheels. I was thinking of sacrificing one set and modifying the rears to fit up front and make them my daily driver wheels... and put 255's or 245's on them.
Originally Posted by PilotSH,Jan 6 2010, 05:20 PM
You're already sitting on the next best thing! Since you're only going to run STR regionally, 4 AP2 rears should be fine. When you start thinking of a serious STR build, then I'd spend the money on some nicer wheels.
Marc, who are you going to get to modify your 8.5" to fit up front? We might as well do both sets at the same time. Maybe we can get a better price break doing that. Just thinkin'.
-Dave
Originally Posted by PilotSH,Jan 6 2010, 01:15 PM
But most of the ppl that have bumped up their rev limiters only use the extra revs when accelerating thru the gears. Most of those people hardly ever touch the rev limiter, let alone sit on the limiter like some autoxers do.
The tracked AP2s with the same setup takes a much bigger beating due to the temperatures the motors reach. An auto-x S2000 will never see those temperatures unless something is wrong. The tracked cars also stay in the revs much longer. The amount of time the tracked cars spend in the throttle in one track day would account for many seasons of auto-x. This is according to the track guys who prep my car and the credible info found here on s2ki.
Also, I would much rather buy a autocrossed S2000 than any one that has been modified for the street, drag, track, pimped, etc. Looking at the field at Nationals, most the owners take good care of them. Again, there are many people having success with the bumped rev limiter and for many years now. That still wouldn't stop me from keeping a fresh motor around as a spare.
Lastly, I never fall out of v-tec when I shift
It should be somewhere above 6200rpm from 1st to 2nd when done properly...
