STR Prep - ECU and Tuning Discusson
So to use the resources here on this forum I have some pointed questions about Emanage on an AP1
1. Who has the best price new?
2. What Greddy items do I need to purchase?
3. What is the best plug and play harness?
4. Any tricks for install and set-up or is it pretty straight forward.
I am working my way through reading the entire thread but thought I might get some quick answers.
Jake, yes, this is how I use mine, on Win 7 64 bit Professional. It is tricky though, need a good solid USB 2.0 printer cable (cheap multi adapter ended one didn't work for me), only works on USB 2.0 ports not 3.0 ports on mine. It also won't connect unless you get the drivers in the right compatibility mode, ie I think it won't connect if you're in normal Win 7 mode but try to open the EMU software itself as runnning in XP Mode, you have to start a separate new VM instance of the XP Mode shell first, then install/run the software from within that. Once there, and connected, may need to enable integration features from the XPMode Tools menu at the top, and also you should see the EMU under the USB menu. If after trying the above, you still can't get it, let me know and I'll try to do it again to remember any steps I missed or try to walk you through it.
2. Should just need the EMU and a harness. A wideband if you want to do your own tuning/monitoring.
3. I'm not sure any completely correct harness is made out of the box yet. I'd modify to the methods Brian at Karcepts posted earlier in the thread regarding map tap vs map intercept.
4. I'd follow the instructions/base map Karcepts posted in terms of wiring, rest should be plug and play. Also, there's a trick to rotate the stock ECU 90 degrees to get the harness wires to fit behind the cover.
I was curious as to how my results stack up with other STR built cars, and just how much more potential I have left. For me, lowering VTEC engagement to 3400 yielded the most torque gain, and surprisingly enough, simply removing the air filter gained 5 whp. I'm happy with how fairly flat my torque curve ended up.
2005, FIPK, Berk header, Berk 63.5mm high flow cat, Invidia catback, AFC Neo
216/153
216/153
216/153
216/153
Do you have a printout of your AFRs?
Also a test pipe will always be a lot better than any HFC.
Nice numbers though. I don't think anyone can argue with 216.
Thanks. I don't have a printout of the AFR's, but they were in the mid to high 13's, with one point up in the low 14's. We added to the fuel percentage values on the NEO and it did bring it back down, but it lost a little power (2whp IIRC). It may have been from the heat in the bay. I have to keep a cat with STR rules, otherwise I would have jumped on a test pipe.
I'm guessing that you are located somewhere with high elevation, that is why you where able to add fuel with the NEO. If you were at sea level, the stock ECU will have gone crazy on you, as it can not see (or at least is not programmed to operate) at any pressure over 1 bar(sea level).
By adding fuel with the NEO you are retarding ignition timing, which is the opposite of what you want to do with the lowered vtec.
Are you allowed a Fuel Pressure regulator in STR? if yes, I would add as much fuel/pressure as possible (as much as the fuel pump an the injectors can take) with the regulator and then use the NEO to subtract some and bring AFR to mid 13s and at the same time gaining a few degrees of ignition timing which will up the power especially midrange. I've heard of people running at almost 100psi fuel press with stock hardware. Not that I'm recommending to go that high.
Another trick which will probably work is to pull out some fuel in the lower revs/throttle (closed loop) with the NEO to force the ECU to compensate,by adding fuel, with the Long Term Fuel Trims which will also add fuel in the high revs/throttle (closed loop). This way under load you will not be using NEO to add fuel, which pulls ign timing and thus hurt power, but only to reduce fuel where needed. Only issue I see with this is that if you remove battery or reset ECU, it will need some time cruising in low speed to bring your AFRs up.
I hope I have not confused you.
... How to 2-step ...
https://www.s2ki.com/s2000/topic/904...t__p__21509551
and here is a pic of my current setting for launching on a very slippery road. Note that my vtec is at 3600rpm so I'm probably stronger than a untuned s2000 at the launching revs. If you go that low on gripy tarmac you will probably bog down.
https://dl.dropbox.com/u/6873948/2st...%20control.jpg
The start revs is your launch control (rev limiter with 0 speed).
the start->normal setting at the bottom is for how long this limiter should be active for. (even 40 is not long enough for me)
the throttle setting says how easy is to activate the launch control. Basically with mine set at 35%, its almost impossible to rev over 5000rpm standing still. You might want to go higher on this, as even if you overshoot the revs and then reach the throttle condition, the limiter will activate and the revs will drop back down to your set point.
The ignition adjustment is quite interesting. It only takes effect if you have the adj. tick box selected. This is ignition retard. On a turbo retard builds boost. On our cars, it just reduces torque, on top of the rev limiter working. Might be beneficial if you are getting too much wheel spin at launch. I believe that the suggestion is not to use it on NA cars, as the exhaust valves get extra hot if you keep on it for more than a few seconds. Also it has the side effect of huge flames coming out of your exhaust if you have no cat and a straight through exhaust and extra loud bangs!!!
And yet it'll rev to 9k when stopped. What?
Does anyone see what I'm doing wrong?
