View Poll Results: What front sway bar do you use?
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
I remember watching some TV show a while ago where Acura was introducing some new formula car and they had the chassis on multi-post shaker thing and they developed the damping the best they could. They put it on the track and it sucked.
It was back to the drawing board for them. If Acura can't work it out with millions of dollars and incredibly smart people, I doubt any of us can either.
So far this year, I've done some changes that are interesting. For the sake of fun and for the fact that nobody seems to run what I do, here's what I've noticed so far:
I installed a 2006 rear bar to replace my 2000 bar. That's about a 100lb/in difference. At the same time I dialed my rear toe from almost 3/8" toe-in to zero. Prior to these changes, my car had a very hard time putting down power on corner exit on slick lots (it worked pretty well in Lincoln). After these two changes, the car was easy to drive out of corners and was much more driftable even on a slick asphalt lot in 55* weather. I thought it was very interesting that 100lbs/in of sway bar was more effective than a bunch of rear toe-in at settling the car especially after I determined that rear toe was incredibly powerful.
It was back to the drawing board for them. If Acura can't work it out with millions of dollars and incredibly smart people, I doubt any of us can either.So far this year, I've done some changes that are interesting. For the sake of fun and for the fact that nobody seems to run what I do, here's what I've noticed so far:
Now, I did have a problem with my 1st Gendron bar at a Peru, IN national tour where it moved around so much that it pushed the bushing out of the mount. After spinning out 3 times in one run Marc knew something was wrong as I rarely ever spun out... Bill was swift to address this and was quickly resolved.
If you figure out what happened, let us know.
-D
Here's the McMaster Carr part #s I ordered:
91412A460
93839A815
90648A215
4483T401
4483T241
The bolts ended up being about a half inch too short, so I had to go to Lowes and pick up some replacements.
For the record, I have the 1 3/8" hollow bar and run it on 4/6 currently.
Originally Posted by steguis' timestamp='1326978803' post='21331429
On topic, my gendron bar is making like a popping sound when I turn on an uneven surface such as going from driveway to street. I think it's the endlinks binding. Anyone have recommendations on replacements?
91412A460
93839A815
90648A215
4483T401
4483T241
So I guess:
91257A630 for the bolts (grade 8 and 1 3/4" instead of the 1 1/4 you posted)
97135A230 for the locknuts (grade 8)
4483T401
4483T241
93839A815
It'd probably be a good idea to add 3/8 washers too
If I’m full of shit please tell me so and explain to me how. I feel like I try to talk technical terms on here 95% of the time and no-one ever really wants to comment back or give their input or knowledge. It’s always “well I just go and drive, sometimes I do ok.” I’m a number, theory, and science based guy. I naturally think theirs a science to everything and everything can be figured out using number and theory’s. Just going out and driving without any knowledge of what your actually doing to the handling of the car when you change that bar setting or turn that knob seems like a running around in circles method of setting up a car. Maybe I should just go drive the car and stop thinking about what effects on handling changes make to the car.
Everything cannot be figured out using numbers and theory. That is where your issue is. You're right that the numbers can guide you to good things to try, but that's really all they can do. There are way too many unknowns to be able to calculate this perfectly with numbers. Your calculations are very simplistic and do not account for a lot of things that are going on.
For example, a large part of the reason I want to run with no rear bar is because sway bars impart a force that works to actually lift the inside wheel as the outer wheel compresses. Springs do not do that. I really want to keep maximum rear traction so keeping the inside rear on the ground would be good. Where is that in your calculations?
As the rest of your post said, there are many competing goals. The only way to know which balance of compromises is correct is to try it.
I guess theirs more then one way to skin a cat.
Thanks for posting endlink numbers that will work. I've seen people post 10+ times asking for part numbers that will work but I never see anyone answer the question. I use a stubby to get on the nut (pain in the ass btw) and a 1/2 inch 3/8 socket on my 14.4v snap-on impact. I can change the setting fairly quick. It also amazes me how much alittle +/- makes on the handling of the car. Im gonna like a rear bar that's adjustable.
06 rear bar and zero toe? I'd be all over the place with that set-up unless your springs are a big stagger, big difference in front to rear camber or the rear is lower then the front. Pm me your full set-up if you get bored. I'd like to look at it.
Currently running 900lb front with Monster bar on full stiff. 750lb rear springs. The car tends to understeer at this moment but just a touch. Feels pretty great but I expect that to change when I install the diff.
Is there a reason to even care about front wheel lift? Mentally, I've never had an association between wheel lift and mechanical grip, but maybe my intuition is off on this one.
Seems to me that a wheel in the air isn't significantly worse than a wheel on the ground that is almost completely unweighted. Graphically speaking... I wouldn't expect to see a "step change" (drop) in mechanical grip as soon a tire lifts. Rather, I'd assume the the weight has shifted complete to the other side of the car pressing that tire into the ground hard increasing it's grip (in the same way downforce would increase grip).
Maybe you lose other things like the cantilever turn in action that front tow-out provides? But, would lots of effort to keep the front tire on the ground really help front grip?
(disclaimer: I am in no way an expert. please tell me if my assumptions are wrong)
