View Poll Results: What front sway bar do you use?
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
Has anyone had clearance problems with the Small Fortune bearing mount rubbing the steering boot? I was trying to install earlier and on the stands at full droop it rubs so under compression it will be worse. Looks like I could grind down the offending area to gain the clearance needed. Anybody else have to do this? How much needed to be removed to gain the needed space? Is there another option?
Figured this is the thread to ask.
TIA
TIA
TIA
TIA
TIA
TIA
TIA
TIA
TIA
TIA
I decided not to grind them down.
[attachment=15457
SC07655.JPG]
Here are a couple of shots. Hard to get a good one lying on my back but the lower edge of the mount rubs on the boot with the steering centered and as it moves though its compression/expansion when I turn side to side. Wondering about grinding down just the bottom of the mount to where the drill hole is in the upper left of the right hand mount shown on the bench photo.
SC07655.JPG]Here are a couple of shots. Hard to get a good one lying on my back but the lower edge of the mount rubs on the boot with the steering centered and as it moves though its compression/expansion when I turn side to side. Wondering about grinding down just the bottom of the mount to where the drill hole is in the upper left of the right hand mount shown on the bench photo.
Interesting that they are so much softer than the Gendron bars.
Originally Posted by IntegraR0064' timestamp='1327856218' post='21363042
[quote name='legend4life' timestamp='1327812445' post='21362279']
Read through the thread, don't believe I saw it, does anyone know the rates (range) or weights of the Ankeny bars?
[/quote]
I got this response from Guy last August
"Justin--My bar is about 15% stiffer than a Gendron bar, and can adjust about 30% and can be done in less than 1 minute. "
