S2000 Street Encounters Stories of on-the-road exploits and encounters.
2 Supercharged S2000s
Old Jun 12, 2006 | 11:47 AM
  #51
IIGQ4U's Avatar
I was wondering the same thing.
Old Jun 12, 2006 | 12:02 PM
  #52
Purple_sky's Avatar
Originally Posted by slimjim8201,Jun 12 2006, 07:51 AM
Your engine does not inject fuel when you are at zero throttle position.
If the engine doesn't inject fuel, not even a little bit, at zero throttle, how can the engine itself run/burn? If you leave your car on for a few hours, wouldn't it run out of fuel? Doesn't it need fuel for combustion when it's on?
Old Jun 12, 2006 | 01:41 PM
  #53
slimjim8201's Avatar
Read the second line of my statement:
"Take your foot off the gas while the car is in gear and not at or below idle and the engine does not inject fuel. "
Old Jun 12, 2006 | 01:46 PM
  #54
Originally Posted by BlownAP,Jun 12 2006, 03:45 PM
please explain. im know nothing about this sorry...... what is the egine doing/ running off of then?
It is still undergoing compression. Air is still entering the chamber and being compressed, but there is no fuel injected (and thereforce no burn thus the power stroke becomes just a stroke).
Notice how different your engine sounds when you lift off. No power strokes. Also, you have a different fluid medium exiting the engine with a totally different temperature. Without injected fuel, you just have air. Without combustion, you have relatively cold air. Different harmonics will accompany this different fluid medium.
Just because your engine is making noise, it doesnt mean it is undergoing combustion. Try reving your engine and then quickly take the key out at about 5,000 RPM. It should sound very very similar to just taking your foot off the pedal with the ignition still on. Untill it reaches idle and catches itself of course...
Old Jun 12, 2006 | 02:40 PM
  #55
IIGQ4U's Avatar
I understand what you are saying now slimjim. I just re-read your initial comment.
Old Jun 25, 2006 | 12:37 PM
  #56
Sideways's Avatar
Originally Posted by zdave87,Jun 8 2006, 07:43 PM
Any reason why the driver on the left crossed the double yellow lines?
Just an optical illusion from the camera angle.
franky
Mar 4, 2013 05:15 PM
s2k_Gamble
Apr 23, 2012 12:01 PM
D's Up.
Sep 25, 2011 08:34 AM
iqbad
Nov 2, 2008 11:40 AM
blessed
Jul 11, 2004 07:56 PM
