4.77 gears quick question..Update
Originally Posted by Stratocaster,Nov 18 2005, 11:52 AM
Backlash should be set to the OEM specs in the Helms manual. If I remember correctly, it is .003
And the 4.77 gears are made by Kia not Mazda.
Originally Posted by Wisconsin S2k,Nov 18 2005, 07:32 PM
nooooooo not .003. OEM settings should be around .012-.014 if memory serves correctly. i know the richmond are much tighter than OEM spec, and they are .006 as you know.
From the Helms manual, Section 15-11
Backlash
Standard: 0.09-0.11 mm (0.0035-0.0043 in)
Minimum: 0.05 mm (0.0020 in)
Differance Range: 0.07mm (0.0028 in)
So YESSSSS
OEM is much tigher then the Richmond specs.
