Another saving weight thread!
Old Jun 8, 2005 | 01:41 PM
CynCrvrAP1's Avatar
my list and savings
j's 70rr exh= 10lbs saved 56 lbs over stock
j's header saved 13lbs
j's intake saved up to 6lbs (from what ive been told)
no extra tire saved and tools 40lbs
cf trunk saved 10-15 lbs
ce28ns 17" wheels saved a total of 5lbs per wheel 20lbs
gutted trunk and no material saved like 5lbs
t1r battery saved 14lbs
spoon brakes save ? but they do save weight(will find out when possible)
theres nor to come but a good person to ask would be AJPWR
Old Jun 8, 2005 | 05:19 PM
afwfjustin's Avatar
I have removed the spare and tools already! I'm also not a fan of the way carbon fiber looks in relation to body parts. If I got carbon fiber parts... I'd end up just painting them to look stock
In reference to my cutting bolts question, I actually read on this forum that the guy saved 100 pounds... I realize that our car probably does not have this many bolts, but I'm just curious to see if anyone has attempted it and how much they saved. Even if only 10 pounds, it'd be worth it to me.
I read that there is some odd 15 pound rubber piece under the dash attached to the firewall... is that needed? What about heat shields under the engine bay? Are those that necessary?
BTW, In the group buy forum there is a single outlet spugen cat back exhaust for under 600 dollars that looks to be an excellent buy. Does anyone have that exhaust and can they give thumbs up in terms of looks, performance, and weight savings?
Old Jun 8, 2005 | 05:20 PM
afwfjustin's Avatar
Originally Posted by kiza,Jun 8 2005, 12:40 PM
OMG!! This is a joke right???
And no, this isn't a joke
Old Jun 8, 2005 | 05:32 PM
CynCrvrAP1's Avatar
hey justin,
i can give you more info on alot of things but my perspective is commming from one who is gonna track the car alot and try and save the most weight as possible. im not jus an owner asking if this thread is for real or a joke jk
anywho you wanna see dedication and a route that im going check this
http://hondatuningmagazine.com/features/05...000/index1.html and look at the trunk pic and how they drilled the shit outta it.
the car weighs in at 2150lbs and has 305 at the wheels and runs tsukuba under the one minute laptime
marcus
Old Jun 8, 2005 | 05:33 PM
CynCrvrAP1's Avatar
"With carbon body mods and the usual interior stripping, ASM's S2000 weighs a lean 2,151 pounds (without the roll cage, ASM says the car dips down about another 100 pounds). Combined with an engine that puts down a claimed 305 hp, it's not hard to see how this car is capable of incredible speed. "
check that out
Old Jun 11, 2005 | 09:29 PM
chipperman's Avatar
If you want to gut your car so it's not worth anything, get a 1969 Nissan 1600 or 2000 Roadster and put the S engine into it. You'll have a 1950 pound car that will really move. Try running your car at an autocross against one of those oldies with a stock 2 liter from 1969-1970 in it and see how well you do. Light weight was around 35 years ago, too.
Old Jun 11, 2005 | 09:58 PM
pantyraider's Avatar
Let's see, there's a lot of things you can remove...
Remove the front and rear swaybar. Savings of probably 40-50lbs
Cut the front beam that goes below the intake, you don't need it, just replace it with a shiny strutbar.
Take out the rollbars, unneccessary because the Cusco ones save tons of weight and are bling.
And finally you can try removing the high "X-bone" frame, that should probably save you the most weight.
lowerlattitudes
Jan 6, 2011 04:30 AM
TookayS2K
May 28, 2008 05:25 PM
ttrriigg
Jul 9, 2006 12:07 PM
iammike
Jul 18, 2005 12:28 PM
charlie
Oct 4, 2001 04:42 PM
