Bad Harmonic w/ Comptech SC -> Is this normal?
I've been thinking about supercharging, but as a catastrophist by profession, first I was worried about the warranty issue, then the #4 cylinder issue. I had never thought about the effect of a new pulley required by the supercharger until I read and meditated on Cdelena's post. This is a potentially serious problem. Honda has certainly balanced this little sucker to run at 9000 revs. I guess the CT pulley must be longer to accommodate the drive for the supercharger. Must change the harmonics of this critical loaded-spinning part. I think it would be very important to the longevity of the engine to get rid of that vibration.
2x6
2x6
What does comptech have to say about it? Mike, I am sure you have or will be reading this thread.
Since this doesn't seem to be an isolated problem, has comptech researched it and what has been found?
Wesmaster
Hi Wesmaster
I got a ride in one of the silver supercharged S2000s here in SoCal, felt the hesitation in lower gears and the rush in 3rd. I didn't notice the vibration Krazik reports, but I think the vibration is potentially a more serious problem than the hestitation.
2x6spds
2x6spds
Originally posted by 2x6spds
Hi Wesmaster
2x6spds
Hi Wesmaster
2x6spds
Check two things: 1) Is the oil outlet at the bottom of the supercharger coming in contact with the frame cross-member? It caused a bad vibration until we cut a "divet" out of the cross-member.
2) Check to see if the top of the airbox is touching the hood when it is closed. A not so bad vibration.
The shifter is like a vibrator on steroids at times..low rpms not too bad but at higher revs LOTS OF VIBRATING...
Wesmaster
