Best way to check for odometer roll back?
Old Apr 12, 2007 | 12:36 PM
  #21
KenS2K's Avatar
Originally Posted by yungjoc,Apr 12 2007, 08:39 AM
Just talked to him and he says, the fronts are original. But he says, the brand is perellis
Then they are NOT OEM tires.
I'm still rolling on my OEM fronts at 36,000 miles.
Old Apr 12, 2007 | 12:37 PM
  #22
plokivos's Avatar
it's easy to roll back. all you have to do is disconnect a wire (which I wont get into) and you drive around how ever long you want then when it's time to sell it, connect that wire back.
simple, but illegal. If you're so curious, I would take the tachometer assembly out and check if anything has been touched. then trace your step back to the entire wire assembly that's attached to the tachometer.
but you will never know if they did what I think they did.
This is a similar way to Evo as well and most cars.
Old Apr 12, 2007 | 12:43 PM
  #23
wills2k106's Avatar
^ If you only cut the output wire the ecu still knows the true mileage. And if it has been rolled the DMV will make them change the title to TMU (true mileage unkown) and the price will drop significantly.
Rolling back odometers isn't as easy as it used to be. You can't just take apart the dash and physically roll the numbers with a small screwdriver. Most cars now have several signals that are sent to the ecu to report mileage. Unless they were able to roll all of them without the ecu knowing then I wouldn't worry about it. A dealer should be able to tell if you are still worried. A low mileage S2000 isn't that hard to find, they are primarily second or third cars that see limited use.
Old Apr 12, 2007 | 01:02 PM
  #24
billo's Avatar
I've got 22.000 miles. Not that unusual to find low miles on this car. If you have other reasons to suspect the seller is dishonest, then walk away.
Old Apr 12, 2007 | 01:04 PM
  #25
yungjoc's Avatar
It might not be easy to roll back the original odometer, but switching out the whole cluster is another way, isn't it?
I am going to talk to him about the tires. He claims to have never changed the fronts and the original owner sold it at 10k miles (reported on carfax),so I doubt he replaced them at 10k
and he has no service/maintenance records.
would a contract with him agreeing that he never tampered with the odometer be a good thing to do? so that if I do find out that it was tampered with, I can take him to court or something.
  #26
plokivos's Avatar
not just the wire, it's something else.
I'll go look to make sure tonight. I better not say it, because this is something a guy at honda told me.
Old Apr 12, 2007 | 01:06 PM
  #27
billo's Avatar
Oh yeah, S0-2's are original. I changed rears at 10,500 and front and rears at 21,000.
Old Apr 12, 2007 | 01:13 PM
  #28
Jay2000's Avatar
There has to be something else about this car that makes you uneasy. I cannot believe you are working so hard to disprove an odometer reading. If it makes you that nervous walk away and buy a new one.
Old Apr 12, 2007 | 01:24 PM
  #29
KenS2K's Avatar
Walk away.
Old Apr 12, 2007 | 01:42 PM
  #30
RED MX5's Avatar
Originally Posted by raymo19,Apr 12 2007, 03:24 PM
There was a thread a while back about a mis-wired yellow box causing the odometer to gain thousands of miles while only traveling about ten. I remember that the guy did get it corrected. Xviper confirmed that it had been reset and went on to say we probably shouldn't be asking how it was done.
That makes sense. Honda has to have a way to set the mileage when they replace whatever unit keeps count. I didn't see the thread discussing this. Do you know whether the mileage is stored in the ECU or elsewhere?
