car lift
Old Jun 12, 2025 | 10:15 AM
ElzWhere's Avatar
Default car lift
Hey all,
I wasn't sure where to post this question. What lifts do you guys use to perform maintenance on your cars? I know it depends on what type of maintenance but for things like fluid maintenance. Is there anything you guys recommend that gives you a good lift height to perform those tasks? Was looking through amazon and wanting all the things. Also looking at future work. I know it's a broad question just curious when getting started with DYI what you looked into and what works. Thanks.
Old Jun 12, 2025 | 10:17 AM
spider2k's Avatar
Active Streak: 30 Days
depends on how much space you have. me personally i wont go near the scissor type lifts and got a 2 post installed in my basement. it cant go full height but i can sit on a stool under the car just fine.
Old Jun 12, 2025 | 10:40 AM
ElzWhere's Avatar
Thx Spider, I guess I should've noted that this will be in my backyard. I have space to use but I don't have much storage space when I'm not using the lifts. I was looking at
portable lifts portable lifts
and these
. I feel like the first ones would be ok to be able to change fluids but I know in the future I'll want to replace the clutch. Also was thinking about suspension in which the second option would be better.
Old Jun 13, 2025 | 06:46 AM
jsenclosure's Avatar
I've used jack stands for years but i work off a 2 post lift more recently and that's the way to go if you've got space for it.
Old Jun 13, 2025 | 07:15 PM
darcyw's Avatar
quick jack.
d
Old Jun 14, 2025 | 12:32 AM
Chuck S's Avatar
My EZcarlift gets used for engine, gearbox, and differential oil changes. No hydraulics. No installation. Slow. Very stable.
https://www.ezcarlift.com/ezcarlift_...nda_s2000.html
-- Chuck
Old Jun 18, 2025 | 05:37 PM
dcdbdave's Avatar
This is how mine sat for it's winter nap. Quick Jacks are surprisingly good and when Costco had them a fairly decent price.
Old Jun 22, 2025 | 02:06 AM
lims2k's Avatar
Quick Jacks are worth it, especially if you're lowered a bit in my opinon. It's way easier on my back now that I don't need to jack up each side to get to the middle jack point
Old Jun 22, 2025 | 09:51 AM
cosmomiller's Avatar
Top Answer: 1
I go low budget, easy and safe.
I have 2x4s that have an angle cut on edge so I can drive up on them. Why? I can get my jack under the front lip and elevate the entire front end at the middle jack point. I use the jack to lift the entire back end using the diff as the jack point. If I need to use jack stands, those are still the two points I use to place all four, two at a time. I leave the jack in place as a backup and MAKE SURE the car is stable on them. I also tell someone I am under the car for emergency cases.
Be aware people have misidentified the front side jack points and have damaged the fender as a result. Make sure you are sure.
Motoxer4life
Jul 8, 2010 06:42 PM
TaeHwan
Sep 29, 2008 05:32 PM
RayRay
Apr 18, 2008 04:40 PM
MRJJ
Mar 11, 2008 01:51 PM
S2000spoon
Oct 6, 2004 10:23 AM
