Cluth pedal rubbing feeling
Old Jun 15, 2003 | 11:55 AM
#22Benny's Avatar
Default Cluth pedal rubbing feeling
Whenever I let my clutch out I get this rubbing noise and feeling, it's kinda hard to explain but it feels like some abnormal resistance that wasn't there before. I can definitely feel it if I've been sitting in traffic for a while and using the clutch a lot. The rubbing only occurs at the catch point, everywhere else is fine. Anyone know what this could be?
Old Jun 15, 2003 | 12:20 PM
xviper's Avatar
Yes, I have this too. Have always had it. Not too concerned about it. I think it might be either the shape of the master plunger seal. When it gets back to a specific point, it hits some kind of ridge and that's what you feel. I suppose, in time, it "could" score the seal and begin to leak. I've heard that some owners have had the master cylinder replace under warranty when this had happened. Those must have been the "worst case" ones. I'm hoping mine won't be a problem for a good long time. If it happens, I don't think the master cylinder is all that expensive to replace.
Another thing it could be is the design of the clutch pedal pivot area. It could be sliding up against one of the two switches there. One is for the starter interlock and the other is for the cruise control disengage. If you're curious enough, crawl under there and push on the clutch and watch if it engages something at the point you feel the resistence.
Old Jun 15, 2003 | 02:21 PM
wanabe's Avatar
i have it too... feels sorta like stepping on a very small mouse.
some slight resistance and a very small noise (i can only hear it in the office garage).
dealer said he has a tsb for it, but i checked and cant find one. will eventually let them try to fix it...
Old Jun 15, 2003 | 08:03 PM
Colin's Avatar
I think this is the clutch squeek some have talked about. I have it as well, a slight squeek and a bit of a rough feel as the clutch engages. The 2000 does not have this at all, and it only developed on the 2001 around 9000 miles. Some have suggested lithium grease on the spring that returns the clutch or the pivot point up on the fire wall. I still haven't gone searching for it cause it's not that big a deal.
Old Jun 16, 2003 | 07:26 AM
wanabe's Avatar
colin- mine is a 2000!
and i got the squeak at about 11,000 miles...
Old Jun 16, 2003 | 08:44 AM
almilli's Avatar
Colin,
Mine's a 2000 too and I have it also. It's really annoying. I took it to the dealer once and the greased up the clutch fork and other stuff. It went away for about 6 months and now it's back again. How annoying...
David
Shaney
Oct 17, 2016 08:56 PM
chrisjm00
Dec 4, 2008 05:41 PM
dangoldeatscake
Aug 19, 2008 10:48 AM
Chr-2004
Aug 3, 2008 01:44 PM
dimi
Mar 16, 2008 04:08 PM
