Definitive S2000 CR Thread
Old Aug 31, 2007 | 11:08 PM
  #1711
Alan in Nevada's Avatar
Originally Posted by MULDER,Aug 31 2007, 12:26 PM
Here is some info on that "Peak Power Indicator"......
Originally Posted by Temple of Vtec
The digital readout for the speedometer maintains its familiar central location, and on the CR, a special green LED indicator is located just to the right of the speedo. The function of this LED is to indicate when the motor is operating in its range of maximum power output. The LED begins blinking when the revs are approaching the range of maximum power, and goes solid when it's in the range of maximum hp.
That's an awful tiny green speck to keep an eye on while trying to stay on the track during a time trial, or even inside the cones during an autocross. They could have done much better. Probably will just watch the tach, which will probably be much easier to keep an eye on. . . . . . will just have to try it an see.
Old Sep 1, 2007 | 10:42 PM
  #1712
The latest issue of Car and Driver, (and also Motor Trend) has a one-page write-up on the S2000 CR. Essentially all of the technical details mentioned have already been posted on this forum, but the Car and Driver testers said that the S2000 CR was "about three seconds" per lap quicker on the Mid-Ohio Sports Car Course than they were able to do with a base S2000.
Old Sep 2, 2007 | 08:59 AM
  #1713
JERO's Avatar
I would like to see the following cars on the same track, the same day, the same (experienced with the track) driver and THE SAME COMPOUND TIRES:
1.) 2000 original
2.) 2002 F20 w/revised suspension
3.) 2004 F22
4.) 2006 VSA w/DBW
5.) 2008 CR
this perhaps will let us all know just how close (or not) these all are on the track.
Old Sep 2, 2007 | 09:55 AM
  #1714
Elistan's Avatar
If you can bring together the cars, I'll bring my tires and will be happy to drive them all.
Old Sep 2, 2007 | 07:59 PM
  #1715
SoCalCraiginDrag's Avatar
[QUOTE=JERO,Sep 2 2007, 08:59 AM]I would like to see the following cars on the same track, the same day, the same (experienced with the track) driver and THE SAME COMPOUND TIRES:
4.)
Old Sep 2, 2007 | 08:01 PM
  #1716
alejo's Avatar
I think like the 2006+ you can just turn it off.
Old Sep 4, 2007 | 12:27 PM
  #1717
STL's Avatar
STL
1.) 2000 original
3.) 2004 F22
4.) 2006 VSA w/DBW
5.) 2008 CR
Add one more to the list:
6) 2004 with F20C and the new gearing that came with the '04s (whichs means it won't be a US model since we only got the F22C models)
I would even be willing to put the 16s with the special Honda S-02s on the above and put it up against the RE070. Both are Bridgestones and both have a treadwear rating of 140.
Old Sep 5, 2007 | 09:44 AM
  #1718
S2kInVaSi0n's Avatar
is the cr even here yet? it saids sept right?
Old Sep 5, 2007 | 10:01 PM
  #1719
s2000Junky's Avatar
Intersting, I would ike to see this too. I think #6) would win. It has the fastest
acceleration combination. Ap2 trans first 4 gears are reduced. It works out to the same as putting 4.44 diff gears in. With the added 1000rpm the F20 has it would work super! With the lightweight 16" wheels it would be even more improved. If you put this combo on the 00 model which weighs about 100pound less then the 04. Now your dominating. 02 model susp. has lighter sway bars so handling isn't as precise. However would be interested to see if it gained any tire grip or not.
Old Sep 5, 2007 | 10:23 PM
  #1720
snguyen's Avatar
they did nothing really but shave off a hundred pounds off the orginal s2000 WOOP DI FCKING DOO!!!! honda all i got to say is im soo dissapointed... make it faster at least and change the body more make it more fat and wide anything! is better than the CR aka type S s2000. UGH!@$^%^&
