Definitive S2000 CR Thread
Does anyone know if the CR has a different passenger side trunk liner since the spare tire is removed? If nothing else, I'd like to get the tire flat fix kit from the CR and the revised trunk liner to get a nice square trunk without the tire bulge... and of course lose the 25# from the spare delete.
Yes, i'm that bored
Yes, i'm that bored
Originally Posted by snguyen,Sep 5 2007, 10:27 PM
even the interior is more worst than the original woop di doo that it helps shave off weight at least have nicer seats god damn. and yellow with blue??
No it ain't not more worst, it's betterer.
Originally Posted by Alan in Nevada,Aug 8 2007, 10:03 PM
The latest issue of Car and Driver, (and also Motor Trend) has a one-page write-up on the S2000 CR. Essentially all of the technical details mentioned have already been posted on this forum, but the Car and Driver testers said that the S2000 CR was "about three seconds" per lap quicker on the Mid-Ohio Sports Car Course than they were able to do with a base S2000.
The S2000 CR is a track toy. No more, no less. That's what Honda intended it to be. All the amenities have been stripped to save weight.
Like Cobras and Vipers, it won't be a car for everybody. If you don't like it, don't buy it. That will just reduce the market competition for the rest of us.
With this in mind as stated (track toy) My complaint is the spec sheet for such a car and i'm sure many others would feel the same. If this is what it is, then it should exude much more performance features, this is what it offers and I am not impressed- weight/ same as fully equiped Ap1, but CR gets no radio or AC to come in at same weight. Power/ same as Ap2/ Suspension and steering ratio/ Same as original Ap1 00-01/ therefor the only benifit to this car stock from the showroom that the Ap1 doesn't have is Wider wheels and some gimicky new featers in the interier and exterier- Nice wings by the way, do they come with teryaki chicken to go with the rice? I'm disapointed to say the least! My bolt on Ap1 will out perform this car and mine looks far sexier! I didn't have to pay $38,000 to achive this either. So assuming my situation is about half of the s2000 owners out there if not more, who is this car aimed at if they are going to use it for what it was supposedly built for?
what a disapointment since so many other cars that have been around just as long as the s2000 have gotton almost twice the power increases and a big step in improvement wile the s2000 got left behind and this CR is just a spit in the face
So let's look at some of the advantages the CR has over your 2001 AP1:
Stiffer chassis
2.2L engine with more torque and more horsepower
Higher performance ECU
Track tuned springs/shocks/swaybars
Shorter gear ratios for 1-2
Taller 6th gear
Smoother shifting carbon synchros
Reinforced differential housing
Stability control
Hardtop for better safety
Hardtop for better aerodynamics
Shift light
Revised oil bolts inside engine
More front downforce
More rear downforce
Lower profile 17" wheels/tires
Stickier R compound tires
Better breather valve
And, it's a new car with warranty, not 6 years old.
Stiffer chassis
Taller 6th gear
Stability control
Shift light
More rear downforce
Stiffer chassis
Taller 6th gear
Stability control
Shift light
More rear downforce
Stiffer chassis
Taller 6th gear
Stability control
Shift light
More rear downforce
If you bought your 2001 new you probably paid more than $30,000 to start with.
$30,000
$3,000 17" Volks with R compound tires
$2,500 hardtop with mounts
$1,000 functional wing
$400 functional front spoiler
$500 chassis stiffeners
$1,000 rear end gears (installed)
$38,400
And you're still down on handling, with less power.
There is no way to get 400 pounds off an S2000 without either spending a ton of money or sacrificing chassis stiffness and safety features. People spend more than $20,000 in search of weight savings and still don't knock off 400 pounds (ASM carbon doors, hood, trunk, hard top, Ti exhaust, wheels etc.). Honda couldn't get anywhere close to that and still meet the crash regulations.
And dream on about an extra 50 HP and more torque. The F20/22 are already nearly maxxed out in terms of (reliable) performance from the factory. FI is most people's easy answer, but you're already talking about an extra $5,000 without even doing the things that Honda would need to do to make it meet emissions.
$30,000
$38,400
$30,000
$38,400
$30,000
$38,400
Ps you keep saying that it makes more power but its just the stock Ap2 motor, 5hp/tq hardly equates to more power. I made that up with a kn filter and tp.
The list of changes certainly didn't sound earth shattering. Just aero kit, stiffer shocks and springs, stickier tires, hard top, and small reduction in weight.
Hard to believe these relatively small changes could shave 2 to 3 seconds off a 60-ish second course, which is quite significant. But then, I guess it is what it is! Or Honda did stuff to the ECU and exhaust that they didn't state explicitly? Who knows. But whatever, at the end of the day, it is faster than a regular S2000.
I remember someone mentioned this earlier, this is a bit like Integra TypeR when that first came out. People would throw in coilovers and this and that to a GSR, and the GSR would still be slower than a stock ITR ... I wonder if the S2000 CR is anything like that
