first time in a ap2
The topic is about how great of a car drive between AP1 vs AP2. Why all AP2 only talking about how fast the AP2 only, and this has nothing to do with topic. If any one ever street racing, they will know that being two cars are equal with over 200hp. Then within 10% hp different are driver race. I don't plan to mod my AP1, but if I do I go TURBO or go home. Let get back to the topic about how the car drive.
lol... Please note that F22 is the only Honda high performance engine that delivers torque, has a good vtec boost AND doesn't burn oil like a Hyundai Excel. This is what you call "just another Honda engine"? while you are probably shopping at Walmart for a gallon of low-quality oil, because it doesn't worth paying more for oil when you are just burning it all...
Originally Posted by mellowyellow999' timestamp='1319831547' post='21110326
AP1 of the F20C RULES...............
http://en.wikipedia.org/wiki/Ward's_10_Best_Engines
AP2 of the F22 just another Honda Engines.
Originally Posted by ZDan' timestamp='1319803700' post='21108972
Actually, area under the power curves is quite similar:
The AP2 isn't faster than the AP1. Published 0-60 and 1/4 mile times/speeds between the two are similar. AP2 makes slightly more power, AP1 has quite a bit more headroom above peak power rpm (which is an advantage, you end up higher on the curve after upshifting) and is slightly lighter-weight.
You posted a chart showing that it does have more power under the curve.
2-3 shift at 8200 rpm would put the AP2 at 5940rpm, but to not punish the AP2 too much, lets say it puts it at 6000.
The same shift in an AP1 from 9000 would put it at 9000(6000/8200) = 6585rpm.
Here is what the "power under the curve" looks like for an AP2 from 6000-8200rpm vs. AP1 from 6585-9000rpm:
So lets sum the areas.
AP2 area under curve = big blue rectangle + small blue rectangle + blue triangle
(8200 - 6000)*155 + (8200 - 7600)*(202 - 155) + 1/2(7600 - 6000)(202 - 155)
= 341,000 + 28,200 + 37,600
= 406,800
AP1 area under curve = red rectangle + red triangle
(9000 - 6585)*162 + 1/2(9000 - 6585)*(195 - 162)
= 391,230 + 39,848
= 431,078
Whaddya know, the AP1 actually has more area under the curve...
Don't try to pick apart my comments as not correct because I am right.
The AP2 is a faster car all around.
It has more torque and a more useful powerband,
tighter gears,
wider tires and a better suspension (stable rear) for less oversteer and increased corner speeds.
I'm done here if you still want to try and argue the facts.
I have an AP1 man, I am not biased about this. It's just the truth.
Actually, i think the whole "area under the power curve" isn't really what's important. Otherwise, a 120hp engine that spun to 20,000rpm would have an advantage, which it really doesn't. So feel free to ignore the squares/triangles in above post...
Important thing to note is that the aP1 is making more power than the AP2 immediately after upshifting, so though AP2 makes more power, it doesn't *always* make more power.
In the end, the stock AP2 is no quicker than the AP1. But it would be with a rev-limit bump up to 8500.
Your a dumbass bro, you are comparing 0-60 tims? the OLNY REASON THEY HAVE THE SAME 0-60 TIMS IS BECAUSE THE AP2 HAS TO SHIFT RIGHT BEFORE 60 MPH, after that the ap2 pulls ahead.
HAVE YOU EVER SEEN A ROLL RACE WITH AN AP2 VS AP1??? AP2 ALWAYS PULLS ON IT. WHAT DOES THAT MEAN? AP2 TRAP HIGHER SPPEDS IN THE 1/4 MILE. What does trap speeds mean? faster car duh
Enough with this dyno plot you found for 2 cars which mean nothing. Why dont you goo look at the dyno section on this forum and compare the 100s upon 100s of dyno through out the entire thread and come back. Why is it that ap1 are putting down 185-195 whp tops when ap2s are putting down 200-220 tops?
We go over stock vs stock, modded vs modded, all on the same dyno, and a lot of the dynos back to back. Irrefutable evidence.
