first time in a ap2
Old Oct 29, 2011 | 02:13 PM
  #121
WhiteSSP's Avatar
Originally Posted by psychoazn
Originally Posted by SlowTeg' timestamp='1319836677' post='21110591
AUC is within 1%, assuming redline shifts, for both cars. Stock for stock, or bolted vs bolted on, it stays the same.
We did some heavy analysis on this in the R&C forum.
One thing to note is that the F20C has a more forgiving power curve, since you use both sides of the hump, whereas a F22C only gives you one side, and shifting early penalizes you a tiny bit more.
I'm not surprised the F20C stock has a much more forgiving power curve, as the f22 really isn't tuned ideally from the factory. Like I mentioned before, it's quite impressive what a flashpro and testpipe will do on an ap2. Lowering the vtec point to ~4krpms and raising the rev limiter to 8500 however makes a world of difference, and the "penalty" for shifting early disappears with a much fatter midrange. I'd be curious to see how the f20c responds to just a testpipe and tune.
The fatter midrange does nothing, especially with a raised redline. A redline shift from 2nd to 3rd would put you at ~5700 RPM. A redline shift from 2nd to 3rd with a 8500 redline would put you at ~6100 RPM. So much for a fatter midrange; that lowered VTEC did nothing, and that 30hp peak gain you see at 5400 RPM will never be used.
A TP and tune yeields just as impressive numbers on a F20C. The only difference is that the F20C requires a full standalone to gain full benefits, whereas the DBW F22C's just need a flashpro.
I've spent plenty of time on the dyno and have multiple flashpro calibrations. Trust me. We've done the math.
This is not necessarily true. on the track, you're not necessarily always in the RPM range from one shift point to the next. There are many times where the time it will take you to shift would cause you to have a slower lap time than if you'd have stayed at a lower RPM range in a higher gear and just powered out of a turn.
So that extra 30whp can make a HUGE difference on track, even if its at an RPM that is lower than what it would be if you shifted at redline.
Old Oct 29, 2011 | 02:18 PM
  #122
WhiteSSP's Avatar
Originally Posted by woodburn
Originally Posted by ZDan' timestamp='1319893484' post='21111801
Actually, i think the whole "area under the power curve" isn't really what's important. Otherwise, a 120hp engine that spun to 20,000rpm would have an advantage, which it really doesn't. So feel free to ignore the squares/triangles in above post...
Important thing to note is that the aP1 is making more power than the AP2 immediately after upshifting, so though AP2 makes more power, it doesn't *always* make more power.
In the end, the stock AP2 is no quicker than the AP1. But it would be with a rev-limit bump up to 8500.
Enough with this dyno plot you found for 2 cars which mean nothing. Why dont you goo look at the dyno section on this forum and compare the 100s upon 100s of dyno through out the entire thread and come back. Why is it that ap1 are putting down 185-195 whp tops when ap2s are putting down 200-220 tops?
Your a dumbass bro, you are comparing 0-60 tims? the OLNY REASON THEY HAVE THE SAME 0-60 TIMS IS BECAUSE THE AP2 HAS TO SHIFT RIGHT BEFORE 60 MPH, after that the ap2 pulls ahead.
HAVE YOU EVER SEEN A ROLL RACE WITH AN AP2 VS AP1??? AP2 ALWAYS PULLS ON IT. WHAT DOES THAT MEAN? AP2 TRAP HIGHER SPPEDS IN THE 1/4 MILE. What does trap speeds mean? faster car duh
I personally know of a 2003 AP1 that dynoed at 203whp back in 2005. It also ran a 13.9@100mph bone stock.
  #123
psychoazn's Avatar
Originally Posted by WhiteSSP
Originally Posted by psychoazn' timestamp='1319838828' post='21110695
[quote name='SlowTeg' timestamp='1319836677' post='21110591']
[/quote]
I can't think of any tracks that I've driven on where this is true. If you're that far out of VTEC, you're in the wrong gear. Your RPM WOT going around a turn at the limit of your tires grip at a given speed will be higher than RPMG WOT going straight at that same given speed due to scrub and slip.
Old Oct 29, 2011 | 02:45 PM
  #124
starchland's Avatar
There is no point arguing between ap1 and ap2 since the driver skill is going to be the biggest factor which will throw out any minute advantage of either car.
Old Oct 29, 2011 | 02:55 PM
  #125
WhiteSSP's Avatar
Originally Posted by WhiteSSP' timestamp='1319926405' post='21112790
[quote name='psychoazn' timestamp='1319838828' post='21110695']
[/quote]
[/quote]
I've never been on a west coast track, so I can't say out there, but here at VIR and Summit point, in a race or even in traffic in a DE, that can easily become the case. You COULD shift to get into vtec, but then you shift back nearly immediately, costing you valuable time.
Old Oct 29, 2011 | 03:45 PM
  #126
woodburn's Avatar
Originally Posted by woodburn' timestamp='1319923514' post='21112703
[quote name='ZDan' timestamp='1319893484' post='21111801']
[/quote]
203 whp LOL that's an average bone stock ap2 and ap2 are hitting 13s very often I even know a Guy how ran 13.6...
Old Oct 29, 2011 | 03:48 PM
  #127
woodburn's Avatar
From a roll race ap2 always wins...no driver involved when roll racing.
Old Oct 29, 2011 | 04:10 PM
  #128
starchland's Avatar
but whats the fun in going straight
Old Oct 29, 2011 | 09:26 PM
  #129
ninjajwl's Avatar
If straight line drag racing / speed is your top priority, I think you may have made the wrong choice in a car. Maybe you chose your S2000 for different reasons, but there is a lot more to the car than which car pulls more. (Even if the difference is very negligible.) Personally, 91 MPH in 3rd gear is pretty darn fun, if you ask me.
Woodburn, with all due respect, some people just do not care about how many milliseconds faster your car is compared to theirs. If I wanted a fast car, I would have bought an Evolution. However, I wanted a car that felt like a true sports car and something that left me with a craving to drive. My AP2 does that very well... However, my AP1 just does that slightly better... even if it is slightly slower. It's all personal preference. Other members on the forum know their numbers far better than I do so I'll leave the technical stuff up to them.
Old Oct 29, 2011 | 10:10 PM
  #130
jh4db536's Avatar
http://www.youtube.com/watch?v=NtdOU-yyZ_w
someone referred to this video.
