hard to shift into 1st and reverse
Old May 31, 2011 | 03:50 AM
starchland's Avatar
what about clutch slave ball thingy?
Old May 31, 2011 | 08:33 PM
project*stealth's Avatar
Originally Posted by wwastrel
i also had the similar problem with my 02. so what i do now before the first engine start, i pushed the clutch all the way down, shift to 3rd, then 4th, then 1st, last is reverse.(if you need to backup on your driveway) if not, i just put 3rd, 4th, 1st, then go. sometimes i also like to go through all the gears before i take off
i dont have a problem doing that... BUT it shouldnt act that way... atleast my last 01 s2k didnt do that... im changing the fluids tomorrow and ill update and let you know if it has gotten better
Old Jul 31, 2011 | 02:35 PM
Reed's Avatar
Bump for results?
Old Jul 31, 2011 | 03:21 PM
HarryD's Avatar
Originally Posted by Reed
Bump for results?
Yes, bump for results?
I had issued getting into just reverse (and not first) on mornings, but a tranny flush with Honda MTF made it somewhat easier.
Old Jul 31, 2011 | 09:01 PM
JackS's Avatar
Rake through a couple of gears first befor trying 1st and reverse. I think many people who have been driving stick shifts do this rather automatically even though it may be unnecessary. Come to think of it, I'm not sure weather I do this or not. If I do, its just an unconsious manuver. Not a bad habit to have BTW.
Old Aug 1, 2011 | 07:16 PM
Bump for results?
changing the fluids helped. i went with amsoil in tranny and diff. plus i just moved to vegas so the addition of heat makes it non existent. i think it was mostly the cold and old fluid. i also re-greased my shifter
Old Aug 2, 2011 | 09:58 AM
FluKy15's Avatar
I am currently using the amsoil tranny fluid, and let me tell you, I wont be using it again. I am going to switch to the Honda MTF for sure. It takes waaaay too long for this fluid to warm up. Its difficult to get into first until its warm, after about 50 kilometers. Honda MTF for tranny fluid is the only way to go!
Old Aug 3, 2011 | 06:40 AM
03silvS2K's Avatar
I have experience with amsoil with previous cars, but it sure isn't the cure for every car. Sometimes, good ole' plain fluids from the dealership is the only way to go.
Old Aug 4, 2011 | 12:37 PM
unison21's Avatar
This happens to me too. If I rev the engine a bit while in neutral with the clutch pedal out it tends to allow me to get into gear a lot easier. Try that.
skyler2k
Jan 20, 2016 01:53 PM
hariku821
Dec 14, 2009 12:16 PM
S2kMarkus
24
Jan 15, 2008 08:53 AM
joe johnson
Jul 21, 2007 12:12 AM
Cyber Logic
Oct 2, 2001 07:24 PM
