HELP! cant remove shift knob
Old Aug 29, 2005 | 04:28 AM
zeusallmighty's Avatar
Default HELP! cant remove shift knob
i tried to remove a Voodoo knob from my '04 and absolutely can't break it loose... i used Blue lock-tight on the threads for installation as directed... it's a spun pearl aluminum so my grip slips a bit, but i'm torquing the shift bar appreciably without ANY give in the knob; i'm worried i'll destroy the linkage if i turn too much...
any advice???
does the panel around the shift boot come up so i can access the shft bar and immobilize to provide counter-torque??
thanks
Old Aug 29, 2005 | 08:47 AM
dozen5's Avatar
i had the same issue with the loctite.
https://www.s2ki.com/forums/index.ph...pic=301602&hl=
vise grips. get one under the boot to cover up blemishes and start twisting the crap out of it. the console should just pop out. just be gentle. i think there's 6? clips holding it down. just pry it off. good luck.
Old Aug 29, 2005 | 09:17 AM
stupid question-- are vise grips a name-brand locking wrench or a type of wrench? should i just go to home depot and ask someone for vise grips?
Old Aug 29, 2005 | 09:44 AM
dozen5's Avatar
it's like kleenex. i think it's a name brand or a name of a tool a company makes. they're technically locking wrenches, i guess. i'm sure home depot will know what vise grips are. good luck.
Old Aug 29, 2005 | 10:00 AM
meth's Avatar
to my knowledge, this is what a vice grip is, and NO, thats not me, that is a google image...
Old Aug 29, 2005 | 10:01 AM
meth's Avatar
oh, and i probably wouldn't use loctite again when putting it back on, as you see what happens. i know other people with the same knob who didn't use loctite.
Old Aug 29, 2005 | 10:34 AM
r_duff's Avatar
dont lie mark, that was u fixing your skateboard last week. i remember
Old Aug 29, 2005 | 11:06 AM
Stratocaster's Avatar
Wait! Before you use vice grips!
Get a piece of rubber or the like, and use it to help get traction. You can do this by hand. Also if you "snap" instead of constant pressure, it will release easier. You just need to break the seal, just like that JAM Jar.
Old Aug 29, 2005 | 11:09 AM
Incubus's Avatar
Static Friction at its best.
KillerBlackbird
Jul 17, 2013 10:07 PM
RedSex2k
Aug 5, 2010 03:25 PM
BelowRadar
Feb 26, 2010 09:44 AM
PilotChris
Dec 28, 2002 10:35 AM
mingster
Dec 17, 2000 02:47 PM
