LATCH RATTLE FIX.......DIY
Old Apr 8, 2007 | 02:40 PM
  #31
Aze85's Avatar
i just did the fix and it works like a charm.
the hardest part was stuffing the ept into the tiny crevice
Old Apr 9, 2007 | 03:10 PM
  #32
jeggy's Avatar
if you remove the 2 bolts that the latch pivots on it becomes 10x easier.
you dont even have to use the ept. anything that can fit in between there will work. it only acts as a bushing to keep the plastic from rubbing on each other. and whatever it is you use, it should be weather resistant. dont stuff tissue paper in there. use seran wrap.
Old Apr 9, 2007 | 03:27 PM
  #33
s2krey's Avatar
im goin gto do this when i get home...the noise makes the car sound OLD!
Old Apr 9, 2007 | 06:08 PM
  #34
NFRs2000NYC's Avatar
UTH mods, add it to the faq!
Old Apr 9, 2007 | 06:19 PM
  #35
S~Factor's Avatar
Freakin' rattling is coming right above my left ear. Can't track it down for the life of me.
Old May 7, 2007 | 08:14 AM
  #36
estuki's Avatar
i just solved all my top rattles with......invidia!!! i no longer hear rattles...or squeeks...or anything... now only if my test pipe would arrive!
Old May 7, 2007 | 11:10 AM
  #37
IrishS2k's Avatar
Will this work for the hardtop latches? Iv'e been trying to fix this problem for a while.
Old May 7, 2007 | 11:44 AM
  #38
StuE.'s Avatar
My passenger latch seems to do this because it's "looser" than the drivers side. Are we really correcting the problem with this or just quieting the sound. it seems to be for my issue that the latch needs to snug down better.
I am currently using the tubing fix on the latch hook that someone else mentioned in this forum.
Thanks,
Stu E.
Old May 8, 2007 | 01:53 PM
  #39
IrishS2k's Avatar
Bump
Old May 9, 2007 | 03:09 PM
  #40
s2krey's Avatar
For mine its on the passenger side somwhere but cant find out where. Sounds like a loose panel but couldnt find anything. I think something fell in the hole where the arms of the top fold....
