need some d-d input
Old Aug 27, 2009 | 02:23 PM
CKit's Avatar
You may be getting close to needing new spark plugs.
Injectors and coilpacks can start to go wonky about this vintage. But not the norm. Just not uncommon.
Don't forget to check brake pad / rotor life and consider a fluid flush if you're going to be autocrossing.
Old Aug 27, 2009 | 02:25 PM
josh7owens's Avatar
Originally Posted by JLUDE,Aug 27 2009, 12:10 PM
The stock air filter is about as close to a true CAI of any OE filter system made. It uses a paper cone filter and a channel that draws cool air directly into the airbox from outside the engine bay.
You will seriously go through rear tires every 10,000 miles if you're driving the car the way it's intended. If you autoX you will want to use a second set of rims for those tires as several autoX's is enough to kill a set of street tires and driving on bald tires in rain or cold weather in the S2000 is NOT fun.
i have 2 sets of wheels already.
Old Aug 27, 2009 | 02:26 PM
josh7owens's Avatar
Originally Posted by Elistan,Aug 27 2009, 01:13 PM
Create an account on Honda's website and register your VIN.
https://www.ahm-ownerlink.com/login.asp?pag...2Fprod_home.asp
It'll tell you the proper maintenance items and intervals, plus any recalls that need to be done.
Change the diff and transmission fluids (I don't recall the interval for future changes though, sorry.) Oil is every 3750 miles, Honda recommends.
Have the valve clearances and brake pad thickness checked, as well as all fluid levels. Brake and clutch bleeds are probably good ideas too.
With mostly highway miles, depending on the tire you get you can expect upwards of 15k to 20k miles per set.
Older S2000's aren't known for any particular reliability issues that I know of, beyond driver-induced issues like lake of maintenance, over-revs, etc.
thanks
Old Aug 27, 2009 | 02:46 PM
2slow2Bfurious's Avatar
did anyone mention brake fluids, if not, then i'll mention it.
Old Aug 28, 2009 | 04:31 AM
MurderS2K's Avatar
good 411 here
tbp5022
Dec 28, 2013 06:12 AM
Greywolf
Oct 12, 2009 07:24 PM
Sik -S
Oct 21, 2004 12:32 PM
RazorV3
Aug 25, 2003 02:41 PM
noTor
Nov 19, 2001 02:20 PM
