Resetting check engine light
Old Dec 22, 2000 | 07:33 AM
pellisS2k's Avatar
Did some stuff under hood this morning (oil filter) that necessitated me disconnecting that small grey wiring wiring harness above the oil filter and just to the driver's side of the passenger-side shock mount.
Anyway, started the car, was greeted by the check engine light. Realized I had forgotten to reconnect these wires. Turned off the car, reconnected, restarted, but the check engine light is still on. How do I reset it?
Old Dec 22, 2000 | 08:33 AM
1Randyc's Avatar
This has been discussed before, but here it is again.
1. put the key in and turn to on and then turn to off, leave the key in.
2. Look under the dash for the fuse box and on the right side locate the fuse in the 3rd slot from the top. There should be 2 fuses one in 2nd and the other one is in 3rd from the top. The top slot is empty.
Now the fuse which is blue I think in the 3rd slot from the top, remove it.
3. After removal wait for 10-15 seconds.
4. put the fuse back the right way, not upside down otherwise it will not work.
5. Turn the key and start the engine and that should take care of the check engine light and resetting of the ecu.
Old Dec 22, 2000 | 09:02 AM
pellisS2k's Avatar
thanks.
Old Dec 22, 2000 | 02:41 PM
nvmys2k's Avatar
We should archive this thread in the technical section
s3kdude
Dec 24, 2010 09:59 PM
EOE
Mar 17, 2010 11:43 AM
Bill L
May 20, 2003 09:27 AM
wake88
Mar 24, 2003 04:12 PM
jhenriq71
Jun 3, 2001 10:03 PM
