SR20 swap into s2000?
Originally Posted by specialk22tt,Dec 24 2006, 11:57 AM
I understand you wanting to do something different, but the F20 has the same displacement as the K20. Take a great engine like the F20 and put in different cams if you want more torque on the low end, don't swap in a new engine. You could easily build this engine, which flows better, to put out high hp numbers for less. No arguements here, I just don't see your reasoning. Either way, good luck
Originally Posted by deathsled,Dec 24 2006, 12:04 PM
the NSX motor, not sure if there's room though
How about a skyline R-34 engine. RB26DETT. I am not sure the rotation and I know it is a big Bitch, (iron block) but think of the power you could juice off this beast.
I saw someone mention the NSX motor, Correct me if I am wrong, I don't think it would work because of the rotation.
The K20Z1 motor (the 2005+ RSX-S motor) is basically the K20A2 motor with the Intake and exhaust camshafts from the ITR motor in Japan (220hp, 152 lb-ft). Lots of potential from this motor, probably easier to get power out of it than the K20A2. With just Hondata and a CAI, the K20Z1 is putting down 208whp / 148 lb-ft according to a Hondata dyno ... http://www.hondata.com/dynok20-05rsx.html ... Not too bad!
IIRC the K20Z1 motor spins to 8400rpms (fuel cutoff), which isn't too far from the 9000rpm redline of the F20C.
I think dropping a K series into the S2000 would be very interesting. Can't wait to see what you come up with!
Originally Posted by 2JZs2000Creator50/50racing,Dec 24 2006, 12:37 PM
Theres room, but $$$$$$$$$$$ ouch!!!!! That would really tear up someones bank account. lets see, $8000 motor, $14,500 lovefab turbo kit, to be under 600hp, IM OUT !!!! That would be pretty cool lookin at a show though!
im interested to see a build up of a K Swap
Originally Posted by clawhammer,Dec 24 2006, 01:10 PM
Why not do a nice NA F20C build?
There is probably a bigger market for built F20Cs than weird swaps into S2000s.
