Strange this morning...
Old Jan 23, 2001 | 06:06 AM
MagusAptus's Avatar
Something very strange happened with my stook this morning. A couple seconds after starting it, I was going to get out and scrap some ice off the windshield (and let her warm up). So, I started to let the clutch out, and the engine started to sputter and cough (it went below 1k RPM), so I quickly pushed the clutch back in-- and the RPM went back up to around 2k. At this point I was calling myself a dumbass for forgetting to take it out of gear-- but when I looked at the gearshift, I was plainly in neutral. I wiggled the shifter a little, then slowly let the clutch out again-- everything was OK this time. It got pretty cold last night (mid 20's?). She only has about 4k miles on her.
Any ideas?
Old Jan 23, 2001 | 06:44 AM
Luder94's Avatar
Was the last gear the car in really disengaged? Could it have stuck in gear even though the shifter was in neutral?
Old Jan 23, 2001 | 06:56 AM
MagusAptus's Avatar
Hey Luder94
I guess that is a good part of my question. Even though the shifter was in neutral, it is possible to still be in gear? After the engine sputtered, I only moved the shifter a little to the left and right (not into any gear) just to make sure that I was not in gear. I'm absolutely positive that the shifter was in neutral. If it makes any difference, I always park (and shut off) the car in neutral also.
Old Jan 23, 2001 | 06:57 AM
meat's Avatar
Banned
This happens on my Teg all the time in the cold as well as the S2000 when I do happen to start it (in storage). I believe that this is the "load" that the trans puts on the engine when letting the clutch out. I usually leave the clutch in for a few seconds until the rpms get up to their "normal" start-up revs and then let the clutch out to let the car warm further.
Hope that helps.
Old Jan 23, 2001 | 07:02 AM
MagusAptus's Avatar
Hey, thanks meat. I've just never had that happen and it sort of scared me.
Thanks.
Old Jan 23, 2001 | 09:31 AM
J R's Avatar
J R
Meat,
You are exactly right. Even though the car isn't in gear, there is a small load on the engine when you let the clutch out. It is not a big worry.
drew260187
Mar 30, 2014 12:10 PM
prancer
Apr 19, 2010 05:05 PM
secondreality
Mar 2, 2010 07:16 PM
CR22
Sep 16, 2009 10:48 PM
fatality122887
Oct 28, 2008 06:09 AM
