Window motor replacement?
Old Jul 23, 2008 | 03:51 PM
Mrfixit687's Avatar
What does the splice look like? You've done this fix to your car?
Old Jul 23, 2008 | 03:57 PM
3ngin33r1's Avatar
well, they can be many different thing depending on the size of cable. If you head to a small hardware store, you can probably find some little compression splices that you simply run each of of the broken cable into and squeeze together.
No, I have never done it in a car but a broken cable is a broken cable and in theory, it should work unless the section of cable that is broken needs to pass through any pulleys or collects onto a drum. Just make sure to cover it with shrink tube so it doesn't scratch the glass.
It's a temp fix.
Old Jul 23, 2008 | 04:00 PM
Mrfixit687's Avatar
https://www.s2ki.com/forums/index.php?act=m...image&img=20909
From the picture of this guy's new regulator, looks like the cable runs into the black plastic sleeves leading to the motor. I dont know if the splice will fit into there?
Old Jul 23, 2008 | 04:52 PM
3ngin33r1's Avatar
Ah well, in seeing that, probably not. Just tossing MacGeyver ideas out.
Old Jul 23, 2008 | 06:40 PM
EmotionalAp1's Avatar
hey thanks for the suggestions guys.
right now i have 1 of 2 choices.
1. buy one from honda with a buddy of mines employee discount. brand new, in box for 191.26 and do the installation myself.
or.
2. buy one that i found on ebay with a buyitnow for 69.00 but is from an 01 and could also be worn in the same spot mine was.
its a gamble with the used one, but a sure thing with the new one. One just cost more... hmm
Old Jul 23, 2008 | 11:56 PM
tekstar's Avatar
if you do buy a used one, make sure it's from an 03+
i replaced my 01 window regulator because some of the ap1 regulators have an issue with the auto-down not working
Slowcrash_101
Jul 15, 2017 07:28 AM
TougeHorseman
Feb 24, 2016 08:42 PM
tyler88
Aug 4, 2012 09:30 AM
s2k-tilldeath
Jul 20, 2012 08:04 PM
EmotionalAp1
Jul 24, 2008 07:29 AM
