1st 2.5L Inlinepro Stroker Kit
Old Oct 31, 2004 | 06:50 AM
  #101
turbo_pwr's Avatar
Originally Posted by gernby,Oct 31 2004, 10:29 AM
Since there haven't been any disclosed results of stock S2000s running the EMS on S2Ki, who are these "people" that you speak of?
Ignition timing is NOT where all the power is. If that were the case, there wouldn't be any power to be gained with a VAFC, which we know is not true. I don't think ignition timing adjustments are going to account for any more than half of the available power.
Playing around with the ignition timing will allow you to tune for torque though once proper A/F has been set. So that is where you will be able to pull the additional gains in hp.
Old Oct 31, 2004 | 09:00 AM
  #102
double11's Avatar
[QUOTE=gernby,Oct 31 2004, 07:29 AM]
Old Oct 31, 2004 | 10:53 AM
  #103
Gernby's Avatar
Former Sponsor
Originally Posted by double11,Oct 31 2004, 01:00 PM
For your reading pleasure: http://www.innovatemotorsports.com/resources/rich.php
I'm not going to argue about where you will find power; and I'll be the first to say don't believe everything you read on the internet. This includes anything that I may post.
Here is one posted on AEM's website:
http://forum.aempower.com/bbs/viewtopic.php?t=10129
and here is a couple of other dyno's that I have found in researching stand alones for the S2k.
I don't know what the intent of posting the innovatemotorsports link was, since it seems to deny your claim as much as it supports it. Almost the entire article is dedicated to air / fuel, with only a single sentence (that I saw) that mentioned ignition timing.
The P1auto dyno plot is puzzling to me. I went to P1auto's web site, and it doesn't show this plot. However, it does show dyno plots from their S2000 project car. The puzzling thing about this is that their project S2000 started off with more power than the one you showed (base line), then only benefitted 17.9 hp with the addition of AEM CAI, Mugen cat-back, Mugen thermostat/fan switch, Toda Racing Header, and AEM EMS. That really doesn't show much support for your beloved EMS. I picked up 13 hp with fewer bolt-ons that were tuned only for AFRs.
Old Oct 31, 2004 | 03:28 PM
  #104
double11's Avatar
like I said, do your own research and I'm not trying to argue with you about where you will find power.
It's a good article, if you have never read it before.
by running rich you are effectively retarding the ignition timing... while wasting fuel.
instead you could just retard the ignition timing with a form of timing control and maintain a much more efficient burn and not blow the gas mileage or leave nice black soot on the bumper.
Old Oct 31, 2004 | 04:49 PM
  #105
honda9krpm's Avatar
Originally Posted by double11,Oct 31 2004, 03:53 PM
I'm still amazed you would spend the $$$ on all that and NOT tune it on a stand alone... People are showing consistent 8-10ft/lb gains across the entire rpm range with AEM EMS's; with peak gains over 20ft/lbs... on stock engines...
Is this with other bolt on mods too or just bone stock s2k?
If it's the later case I find that very hard to believe too. You will gain some power after vtec but not very much b4 vtec at all. I would think it's a lot more to do with dynovariation and who turn what knobs.
Sure, you can gain some more power with the stock f20c with correct intake and exhaust mods. However there are little difference in gain between a vafc and aem ems for such application. The only real extra benefit of the aem ems is that you can readjust the knock sensor where as the piggyback + stock ecu combo is fixed. I believe this is partly why the s2k loses power when you lower the vtec engagement point due to knock control. This is only my theory and has not been tested yet. What do you guys think of this theory ? Has anyone successfully changed vtec engagement point with the aem ems and stock/near stock motor without losing power.
BTW the aem ems dyno gain on the aem forum was with a V2 aem intake.
Nice result whites2000@16. Thanks for sharing
Old Oct 31, 2004 | 05:31 PM
  #106
double11's Avatar
The actual numbers of a dyno can be manipulated by correction factors or gear calculations, but the shape of the graph will be the same.
when you look at dyno graph the horsepower plot will show you the VE of that engine. you can see in some how power will start to fall off up top, the engine is probably choking... or not getting enough air. there are a few trick ways to tell if the cams, TB, Exhaust may be the limiting factor or bottleneck.
Changing the VTEC crossover within a few hundred rpm up or down will only smooth the transistion, on a stock cam/intake/exhaust engine. The way to tune for the best power out of a vtec engine is to tune with it off up past your estimated vtec crossover; and then tune with the crossover set well below your estimate. the point where the two plots cross is where I would set the crossover to start tuning...
This works for FI and n/a.. you will probably find a much lower crossover can be used with FI.
Old Oct 31, 2004 | 06:09 PM
  #107
Gernby's Avatar
Former Sponsor
That doesn't work as well as it sounds. Setting VTEC lower than optimum will cause a dip in power that extends beyond the optimum point. You also have to carefully tune the air / fuel ratios before and after the VTEC engagement to give a "best case" VTEC transition. What worked best for me was to set my VTEC engagement point at 5400 RPMs, clear the fuel controller, fully tune with the WBO2, look at the resulting curve, then raise the engagement point to 5500 RPMs, clear the fuel controller .... on and on. This wasn't easy, but the results were much better than when I used the "intersection" method.
Old Nov 1, 2004 | 08:03 AM
  #108
double11's Avatar
I only said it was a starting point. If the engine is not heavily modified, the stock crossover is a good starting point.
Old Nov 1, 2004 | 04:34 PM
  #109
honda9krpm's Avatar
We know that vtec is noisy and if you drop VTEC engagement point too low the oem ecu might think that it's knock rather than normal vtec noise. I had the same experience when I had the VAFC and AEM intake.
Do you think that the power loss is due to the inbuilt knock control on the OEM ecu?
Old Nov 1, 2004 | 05:01 PM
  #110
double11's Avatar
Possibly, most of my experience is with stand alone (aem) and not piggybacks. With a standalone you will be able to see what the knock sensor is doing, and by what the power is doing you will be able to tell if it's knock or noise.
