1st 2.5L Inlinepro Stroker Kit
gernby- if i understand you correctly my question is, is it possible that inline configured the ecu to only operate in open loop mode? Also when you say some RPM point is that a variable that the computer calculate based on other perameters or is it a known number?also could inline have set it up as if closed loop operates at wide open throttle and at partial throttle it ran open loop and used the vafc to correct it? how do you get a correct set up if the stock ecu is constantly trying to learn then the ecu will operate differently and in turn make the afc be inconsistent
please see my edit to my previous post as i HAVE NOT chaned the setting inline gave me
Originally Posted by AusS2000,Oct 22 2004, 12:20 AM
The E-manage was fine for my set up. Contrary to your predictions my engine is still running fine. My upgrade to the AEM EMS hasn't netted me anymore power. It's just allowed scope for my future plans.
just for clarification I predict that your engine will blow not about power gain
drive it like it should and you will see what I mean
Who care if you made or lose power with a new EMS. Who is stupid enough to say that you will gain power by just changing ems
Who care why you change your ems. Generally smart people would only change it if there is a problem or change it when when they upgrade not just in case of upgrade.
Why are you rehashing this rubbish? How about actually giving this guy some helpful advice if you're so knowledgable. The fact that even when you want to agree with me you try and turn it into an attack (your first post in this thread) by misquoting and misunderstanding me just shows what a defective unit you are. For pete's sake just put me on your ignore list and leave me there. You'd be doing everyone a favour.
Originally Posted by white_S2000@16,Oct 25 2004, 02:16 PM
can you eleborate im not quite understanding what your saying? your telling me my engine is going to blow not because of power gain?? drive it like i should, how am i not driving like it should be?
hmm is this a personal issue between you two if it is please resolve your peronable problems on PM. I already have the camera lined up im hoping to edit some video of my car now while im breaking it in.
AusS2000, you brought back the discussion not me. Take a good look and learn to read if you need to.
White, I was addressing AusS2000. I was just clarifing his statement. He's good at accusing me things. He got on my nerve during my difficutl time and I will definitely goes out of my normal way to return this favour. Ignore it white. As for his advices on ems
I wouldn't even pay attention to it too much but that is just me
My engine stuffed up because of a spark plug failure. AusS2k tried to prove that it's the ems and tried to pulled up some stupid theories which he can't prove and still can't prove about the vafc. The truth was that he couldn't get it to work on his comptech system and blame my failure with the vafc when he did not know what the vortech has at the time. He then try to BS his way out of that.
If you ask for a recommendation for your car's ems, I would say 440cc injectors and emanage/AEM EMS. Sorry if this is aldready recommended as I have not been following this thread that closely.
Originally Posted by gernby,Oct 24 2004, 09:41 PM
Closed loop is the state that occurs while NOT at wide open throttle AND when below some RPM threshhold.
BTW, is you ECU backup fuse still in place? If it is NOT there, the ECU will not learn to tune out the VAFC, but it won't ever run very well at partial throttle
If they did pull the backup fuse just to make it work, that would be a serious bandaid.
