Aircon Compressor Clutch
Hi all - this is my first post in this forum.
I own an AP1 - I have noticed that the AC clutch doesn't spin at all even with AC turned on.
I check the wire by multi-meter and can't see any voltage going to the compressor.
For testing - I connected a direct wire from the battery and the AC clutch worked - also the aircon is blowing cold air.
I check the fuse under the hood and swap them over with the horn but still no luck.
Appreciate any advise.
There's a load protector on the compressor which also acts like a fuse, have you checked this?
