Ap2 block with Ap1 head
Old Apr 18, 2017 | 04:06 PM
patmj2002's Avatar
Default Ap2 block with Ap1 head
does a Ap2 block work with Ap1 head ? please advice thanks
Old Apr 18, 2017 | 06:13 PM
JUSTINTHECOASTIE's Avatar
Yes it does. Be sure to re-use the appropriate head cover/ sensors, meaning if you have a 2003 S2000, found a 2005 motor you want to swap into your 2003 chassis, re-use your 2003 head cover
Old Apr 18, 2017 | 06:15 PM
Nerd-Vol's Avatar
https://www.s2ki.com/forums/s2000-na...ility-1043254/
Old Apr 19, 2017 | 04:33 AM
AngryTurtle's Avatar
I think this only applies if youre swapping and 00-05 head into an 06+
Old Apr 19, 2017 | 04:50 AM
Slowcrash_101's Avatar
The blocks are almost entirely the same from 00-09, I think the main difference in the blocks is the crank sensor. Obviously make sure you have the right pistons for the cylinder bore, and right bearings for the crank, other than that have at it. You gonna buy that Ebay block?
Old Apr 19, 2017 | 08:51 PM
it applies to both, it's the easiest way. I've don't both ways first hand experience
Old Apr 19, 2017 | 08:52 PM
depends on if he/she uses the 04-05 F22c or 06+
9k-Xtc
Dec 18, 2009 09:09 PM
scutrCR
Dec 25, 2008 09:55 AM
TurboR
Jul 3, 2008 05:59 AM
Mr. Francesco
Jun 2, 2008 02:33 AM
