Blow-by
Old May 12, 2008 | 05:14 PM
\\s2kris//'s Avatar
A catch can after a hard 20 min run sounds like a bit much. Have you tried a leak down or comp. test. I had a boosted IS300 with the same problem it turned out to be a blown ringlanding.
Old May 12, 2008 | 05:48 PM
NoTorkS2k's Avatar
Ditto. Like I said above. . That much blow by has gotta be piston rings.
Old May 12, 2008 | 06:08 PM
icemans2k02's Avatar
subscribing as i have this issue on track, with no catch can on stock ECU. good luck
Old May 12, 2008 | 07:35 PM
Turn-R-Us's Avatar
i plan on doing a compression check as soon as the new spark plugs arrive. I figured I would get two birds with one stone.
I have a hard time thinking the piston or rings are bad as the car feels fine on the stock ecu.
Old May 13, 2008 | 06:39 AM
SC_Highlander's Avatar
what volume will your catch can hold? I run a 1 pint can, and on some tracks I have to empty it after every session. I've never filled it up in one session, but it has enough in it that if I don't empty it, I fill it up during the next session and start blowing smoke.
Short
Jul 23, 2016 05:00 PM
mnr vortx f20c
Apr 18, 2011 01:32 PM
woo
Jun 16, 2006 11:43 AM
IIGQ4U
Apr 4, 2006 12:53 PM
BigTed
Oct 15, 2003 07:30 AM
