A/C Compressor Coil
Old Nov 21, 2007 | 09:10 AM
trinis2001's Avatar
Thumbs up A/C Compressor Coil
Is this a job for a non too talented tinkerer? Looks like remove air box, then deal with the one bolt, then figure out where all the little clips fir after they fly out.
Old Nov 21, 2007 | 09:38 AM
camuman's Avatar
you would want to have the freon removed by a shop. then you could replace the compressor, then either you charge the system and hope there is no leak or bring back to shop, have them pressure test the system, then recharge it.
not hardest job, but freon evacuation/recharge makes it a little pain in the ass.
Old Nov 21, 2007 | 12:11 PM
french3sd's Avatar
Why would you want to change the A/C compressor oil... ...typicaly it's good for the life of the compressor. If you do open up the system plan on changing out the accumulator drier which is the filtering device for the system
Old Nov 21, 2007 | 01:24 PM
trinis2001's Avatar
Thanks, I think I'll have the A/C people do it. Not oil- Coil. It seems to have gone according to the mechanic. No AC for a couple of weeks now. Got the part so just to throw it in.
Old Nov 21, 2007 | 01:40 PM
jeggy's Avatar
do you mean the clutch? i am unfamiliar with any "coil" relating to an A/C compressor.
Old Nov 21, 2007 | 02:00 PM
french3sd's Avatar
OPPSS..I ned to learn how to read better....
Old Nov 21, 2007 | 03:26 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you mean the AC clutch, OR the magnetic coil, there is absolutely no reason to disturb the freon.
This is an external part of the compressor. It takes a little skill and patience, but can be done with the compressor in place. I've done 4 as a result of flooding
Old Nov 22, 2007 | 07:56 AM
trinis2001's Avatar
Turns out not to be the AC magnetic coil/clutch, but the heat sensor that sits on top of the compressor that controls the coil/clutch thingy in case the compressor is getting too hot. It needs to be replaced. They just bypassed it for now until I get one.
Anyone know the part number for that?
jjaypal
Apr 18, 2017 09:14 AM
HighwayStar
South Florida
Nov 6, 2015 01:04 PM
ScienceofSpeed
Feb 18, 2009 12:46 PM
sookie626
Jun 24, 2007 10:06 AM
Asura
Jan 3, 2006 05:03 PM
