CEL because of test pipe. will a VFAC/VFAC2 help?
Old Dec 2, 2004 | 12:34 AM
ttang's Avatar
Default CEL because of test pipe. will a VFAC/VFAC2 help?
I have the Spoon test pipe installed with the O2 sensor plugged in but because I don't have that thing that tricks the sensor, i have a CEL.
Will a VFAC or VFAC2 compensate it somehow so the light goes away or do i still need the thing that tricks the O2 sensor?
It's kinda a technical question so I figured somebody here must be able to answer it!
Thanks guys!
Old Dec 2, 2004 | 07:41 AM
sebrings2k's Avatar
no...you will need some kind of electronic/mechanical O2 simulator to eliminate the CEL. Removing the backup fuse is another option.
Old Dec 2, 2004 | 07:55 AM
xviper's Avatar
A vafc is for altering the a/f and vtec point. It not have any affect on the CEL. You should put in a mechanical O2 simulator:
https://www.s2ki.com/forums/index.php?showtopic=229959
Pulling the BACK UP fuse will make your car idle and run really weird.
Old Dec 2, 2004 | 09:06 AM
Tinker219's Avatar
Did this on my SRT4(just a 2" pipe w/bung welded out there), worked great! Then I got Stage 1 which basically eliminates the 2nd 02's function
Old Dec 4, 2004 | 02:29 PM
ttang's Avatar
ok! just checking! thanks
Sexi2k
Nov 30, 2017 04:29 AM
snoodge
16
Oct 29, 2009 06:33 PM
nightcrawler7188
May 28, 2007 05:15 PM
stena
Feb 16, 2006 11:58 AM
SC-SUZUKA
Nov 7, 2002 11:05 AM
