check engine light please help
Old Aug 21, 2013 | 03:01 PM
sandcastle's Avatar
Default check engine light please help
so about 3 weeks ago my CEL came on coming down the highway, i freaked of course, i was about 5 min from home and it was driving fine (no misses) so i drove it home.
the next day i took it up to the shop where i work and connected the obdII and it indicated the fuel cap was loose so i checked it and it was a little loose so i tightened it erased the light and problem solved but...
yesterday it came back on!!! so i took it again and i got the same code for the gas cap/system fuel leak (something of the sort)and then air pump!
now my question is do these go hand in hand or do i have to separate problems? how do i fix them?
on the gas cap could it just be cap? is it just not holding any more?
and the air pump, what the best way to fix this? replace it? iv read something about an air pump delete?
thanks in advanced
Old Aug 21, 2013 | 03:17 PM
iamxpl's Avatar
gas cap gonna take a few times. happened to me to.
Old Aug 21, 2013 | 04:45 PM
franky's Avatar
check the condition of the o-ring on the gas cap. If the o-ring is missing or cracking, it will not seal properly.
Old Aug 24, 2013 | 12:11 PM
sandcastle's Avatar
the seal looks ok ill give it a while longer but what about the air pump issue?
Old Aug 24, 2013 | 09:40 PM
Wolf95's Avatar
Make sure you spin it more than three clicks. These caps tend to throw that code a bit if it's not the OTHER evap code where I believe the purge valve tends to fry.
Air pump should be a separate problem.
Old Aug 24, 2013 | 09:59 PM
franky's Avatar
for the air pump, you can do a continuity test on the air pump relay which is next to the air pump.
Old Aug 25, 2013 | 02:15 AM
INDYMAC's Avatar
I get that code ocassionally too. I think there is a TSB out there somewhere that has to do with a gas tank filler neck change. Mine isn't annoying me enough to look into that further yet.
Old Aug 29, 2013 | 01:01 PM
sandcastle's Avatar
thanks guy ill keep all of this in mind if the light comes back on i hoping that is nothing serious though
liquid6
Aug 25, 2019 04:43 PM
cjts2000
Sep 11, 2017 04:19 PM
S2G4life
Jun 14, 2014 08:57 PM
hawkman199
May 23, 2012 05:03 PM
bballplaya210
Aug 30, 2007 04:14 PM
