Clutch installation problem.
Alright so i got a competition 1420 stage 5 clutch, comes with new everything i.e. throwout bearing pilot bearing alignment tool pressure plate and disk. also got a flywheel. everything went alright for the most part until i get everything bolted back together.
I started noticing trouble after i bolted the trans back up and tried to put the slave cylinder back on. when i went to shift the fork to the rear position it wouldnt move by hand so i used a wrench lightly.
Once everything was back together i hopped in the car and noticed that the clutch pedal was insanely hard and it wouldnt go into gear. it WILL go into gear when the car is off though.
anyone have any ideas or solutions? the car will be down until saturday when i get it back up on a lift and start over so i have a few days to get a plan of action going. help is much appreciated because i definitely want to avoid taking it to a shop and spending $500+.
mine was like this 2x diff times the first was i had the fork in the wrong place second time the slave cylinder was locked up, break open the bleeder screw and push the rod in all the way then realign and bleed you should be OK then.
