Clutch Pedal
Old 06-26-2008, 05:39 PM
UFOGoldorak's Avatar
Default Clutch Pedal
Hey guys,
Just past 40K miles on my '05 S2000. I'm now starting to have an issue with the clutch pedal right at the start of a push. I dont even have to be in gear. ie: sitting in the drive way with car on in neutral, pushing down on the clutch pedal feels as it should. However if I were to rev it up to about 5K+ and push on the clutch pedal again it gets a little stuck at the beginning. Driving the car produces the same results. The higher the RPM the stickier the pedal gets.
Any ideas?
Thanks,
Paul
Old 06-26-2008, 10:28 PM
dbzerk's Avatar
All i can think of is that your throw out bearing and shaft needs to be greased up..
Old 06-30-2008, 03:06 PM
leegungiah's Avatar
I have the same problem with my S2k(47000km), Honda SA said the clutch master cylinder needs to be replaced.
Old 07-01-2008, 05:24 AM
leegungiah,
So does yours do it with out any load on it (neutral)?
dbzerk,
Is that something people do on a regular basis? Am I not better off waiting for a full clutch replacement since the bearing gets replaced with it..? I can't possibly have more than a couple thousand miles left on this clutch. It hasn't seen an easy day in its life, surprised it went past 20K.
wokadowokado
04-22-2013 09:11 AM
Croc
04-06-2011 10:10 AM
tngay510
05-10-2010 05:33 PM
adv2000
South Florida
09-07-2007 09:17 PM
Big_Al
11-11-2005 11:45 AM
Quick Reply: Clutch Pedal
