Clutch problem
Old Nov 5, 2008 | 07:03 AM
DDuds2k's Avatar
Default Clutch problem
Hey, I was hoping someone could help me out.
For the last couple days my clutch has felt soft. I just had the clutch replaced probably a year or two ago, but have unlikely put more than 4-5k miles on it since then.
When i push in the clutch, not until half way down to i feel any pressure. It engages perfect, and there is not grinding or anything, but i can press it down with basically no effort until about half way to the floor, and then i get some feedback. Can anyone explain what this could be, or what i should do?
Thanks!
Old Nov 5, 2008 | 09:16 AM
jyeung528's Avatar
bleed the clutch fluid and clean the reservoir.
Old Nov 5, 2008 | 09:49 AM
SC_Highlander's Avatar
check the master and slave cylinders for leaks.
Old Nov 5, 2008 | 11:32 AM
jyeung528's Avatar
even the appearance of leaks in the master and slave cylinders can be fixed with by bleeding the clutch fluid and cleaning the reservoir.
i had an obvious leak in my master cylinder 3 years ago, and bleeding the clutch fixed the problem...have not had an issue since.
the mechanic that identified the leak would not bleed my clutch because he said it was a waste of time, that i had to change the master cylinder. i said i'd pay him to bleed the clutch, but he refused to.
well, i bled the clutch myself and obviously it fixed the problem, so try the bleed first before changing the cylinder due to an appearance of leaks.
Old Nov 6, 2008 | 07:17 AM
DDuds2k's Avatar
thanks everyone!
WarrenW
May 30, 2013 09:03 AM
Jag528
Jan 24, 2012 03:21 PM
03S2
Feb 20, 2011 02:17 PM
epaplia
Oct 20, 2008 10:16 AM
Turbo_tim
Jan 7, 2008 04:29 AM
